P28 Ecu/auto To 5spd Conversion
Old 02-01-2003, 04:19 PM   #1
Rep Power: 16 Spyderturbo is off the scale
Hey guys. I have a D16Z6 that I am getting on Friday to swap into my 94 CX hatch. I was out at the yard today and I picked up an automatic P28 ECU for a to good to pass up price of $40 who does conversions to 5spd, I was planning on chipping it anyway. I figured worst case scenario I will have to sell it if it can't be made 5spd....
Any input or advice appreciated, I tried a few keyword searches but nothing came up for me....
-Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
2002 Explorer Eddie Bauer
Spyderturbo is offline   Reply With Quote
Old 02-01-2003, 04:25 PM   #2
Rep Power: 26 2 litre EG is off the scale
Send a message via AIM to 2 litre EG
Ericks Racing can change the ECU from Auto to Stick.... where are you located???
Jason -
2.0L ls/vtec - 13.23@107 on slicks
<a href=\'http://www.hondashowoff.com/profile.php?id=3042\' target=\'_blank\'>My Honda Showoff Gallery</a> - Vote for Me!!!
<a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=178\' target=\'_blank\'>My Gallery on HondaSwap</a>
<a href=\'http://www.hondaswap.com/gallery/album.php?mode=view&album_id=311\' target=\'_blank\'>My Other Album</a>
2 litre EG is offline   Reply With Quote
Old 02-01-2003, 04:27 PM   #3
Located in PA, so it is possible to change it. Excellent
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-01-2003, 04:28 PM   #4
yeah it is... you can send him the ECU, with instructions of what you want programmed on it [fuel curve, Vtec Engagement, Redline etc etc].... i had an auto PR3 before and i had mine changed over there.... check out his website in my signature
Jason -
Old 02-01-2003, 04:34 PM   #5
Thanks man, I will definately be checking him out. I also posted some wiring questions about my swap, this is my first Honda swap so I'm still feeling around for the wrench under the car As far as fuel curve and specs I have no idea, I just want a lower vtec engagement point and a little higher redline, nothing crazy, he will know what to do if I give hime those numbers and my intentions with the motor??
Thanks, Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-01-2003, 04:36 PM   #6
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
if you just need to convert it from auto to 5 spd and dont care about re-chipping it then you can do it yourself rather easily. it involves removing 1 resistor
pills_PMD is offline   Reply With Quote
Old 02-01-2003, 04:38 PM   #7
I'm not overly concerned with re-chipping it, the main thing is to get it to run 5spd. This sounds good to me so how simple is this, and where can I get the info on what one to remove?
Thanks, Matt
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-02-2003, 05:17 AM   #8
Rep Power: 20 AllMotorMonster is an unknown quantity at this point
Thanks, Matt
Matt -
It's more than just 1 resistor, but the one they are talking about is just below the 28 pin eprom location.
RP17 and RP18.
Take both out, and put in a 0 ohm in RP18.
You also should remove the Transistors at IC15 and 16 along with the corrosponding resistors, and such.
If you want, I can do the whole conversion for $20 + return shipping to you.
If you want a good all motor chip with redline set at 7500 (not the 8000+ you see on egay) let me know. I can do this as well.
AND, (sorry if I'm rambling) if you DO want to do the Auto/manual convert & chip the ecu. I can send you a already done unit + core charge, when you send me back your auto P28, I'll refund the core charge.
If you want to know more, or you are interested, PM me or hit me up on e-mail.
Late.
<a href=\'http://www.ask.com\' target=\'_blank\'>Learn everything you ever wanted to know about engine building, chassis setup and ECU's</a>
AllMotorMonster is offline   Reply With Quote
Old 02-02-2003, 03:47 PM   #9
Thanks, Matt
im a lil late here but yeah he will know what to do... but generally people will move VTEC engagement to about 5500, and Redline to about 8500-8600...
yeah AllMotorMonster, it may be available on "EGAY" but it works just fine for me [not that i bought my ECU on EBAY], but there is nothing wrong with 8000+ redline on a honda, especially and All Motor one
Matt: all you gotta do is let Erick know what modifications you have and are planning on doing in the future of your car and he will come up with a good set up
Jason -
Old 02-02-2003, 04:59 PM   #10
2 Liter -
I agree there is nothing wrong with a 8+ redline, if we are talking about a GSR or B16A.
BUT, if you are speaking of an LS, CRV or SOHC VTEC (In stock trim), then yes, there is something wrong.
RPM does NOT = HP on stock engines.
For a GSR or B16A (99-00 Si) I'd go with 8800 MAX redline.
If you have a SIR 1 (88-91 B16A), make sure you have at the minimum the manual version of the B16A head, because if your engine was an automatic, the springs are WEAK, and cannot withstand any more than 7800 RPM.
For any SOHC VTEC engine with stock valvetrain, I'd go MAX 7800 RPM.
Whatever you do, just make sure you protect your engine.
Old 02-02-2003, 07:25 PM   #11
www.hondata.com
go there and look at teh installlation manual it tells what resistors need to be removed.
Old 02-03-2003, 07:55 PM   #12
Pills PMD.....can you be more specific on where to find the info, I can't locate it......sorry......
-Matt
2000 Civic EX Coupe
1990 Mustang LX 5.0
Old 02-05-2003, 05:46 PM   #13
http://www.hondata.com/downloads/installation.pdf
remove rp17 and install a jumper across rp18
there you go manual ecu
look at the bottom of page 9
Old 02-05-2003, 05:59 PM   #14
Rep Power: 23 chet is off the scale
Send a message via AIM to chet
kenji chips ecu's.
email him at kenji211@tampabay.rr.com
"I have a few chipped P28 ECUs in stock.
Many programs to choose from.
Custom VTEC and rev limiters on most programs."
he emailed me with this...and i'm using one of his chipped p28's. if i have good luck with someone i'll continue to refer them.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a>
chet is offline   Reply With Quote
How bout a prelude 5 lug conversion? Seany-izzle Wheels / Suspension / Tires / Brakes 20 07-14-2007 01:58 AM
95 Civic Hatch to a 96 conversion YouKnowWhoIBee Body / Exterior / Interior / Cosmetics 10 07-19-2004 01:10 AM
93 Coupe Disc Conversion & Auto to Manual Conv. j177oney General Tech and Maintenance 4 03-30-2004 08:39 PM
Obd0 to Obd1 conversion 2fastaccord HYBRID -> ED-EF / DA 1 01-28-2004 02:15 AM
D Series Vtec Conversion timEspeed HYBRID -> EG-EK / DC 0 03-25-2003 08:14 AM
