Perhaps the dumbest dpfi-mpfi question ever
Old 08-11-2008, 09:06 PM   #1
Rep Power: 0 hunterhound is on a distinguished road
Default Perhaps the dumbest dpfi-mpfi question ever
Here it is, really, really, dumb ass question, brace yourself:
I have a d15z1 (vx engine) complete with almost the entire engine bay harness, the p07 ecu, an obd0 to obd1 conversion harness, and an mpfi fuel injector resistor box, going into 89 dx. The question is, other than wiring the resistor box, what other wiring conversions are needed? If I'm using the proper ecu, then I should not need to repin/splice any wires at that point. And the conversion harness should make the connection to the ecu a piece of cake, right? Enlighten me to why I will need to do all of these wiring changes I have seen on-line because it seems as though they all relate to converting dpfi to mpfi AND using the ecu that came with the dpfi engine/chassis.
hunterhound is offline   Reply With Quote
Old 08-12-2008, 08:45 AM   #2
Ride:  91 civic DX
Rep Power: 3 Justin91civic will become famous soon enough
First off the injector resistor box is only needed for a obd0 car. If you are using a obd1 injectors and ecu then the resistor box is not needed. If you want clarification on that then check out our reference section. The second thing is that if you are using a obd1 to obd-0 conversion harness then you will still have to add wires and repin the point where the original ecu would go. You have to use the engine harness that came with the car not the engine. The reason why you have to add the wires is becuase on the original engine harness you are missing 2 injector wires along with the cyl. pos. sensor wires. You will have to add those wires and then connect it up to the conversion harness and then your ecu. If you go this route then you will need a 0bd-1 to obd-0 dizzy conversion harness as well.
Justin91civic is online now   Reply With Quote
Old 08-12-2008, 11:37 PM   #3
Sounds great but.......most of the dpfi to mpfi wiring instructions I've seen online involve using a resistor box and taking wires of the A pinset and attaching to resistor. See link here DPFI to MPFI writeup
Do I need to do everything else but this step, if not can you point me in the right direction?
Old 08-13-2008, 08:42 AM   #4
Ride:  91 civic DX
You will just wire up the fuel injectors without using the resistor box where it says connect wires to resitor box omit that step and connect those wires directly to the injectors. The yellow black wires are the hot and the other side connects to the ecu and that is the ground. So splice in the yellow black wires on the two dpfi injector clips and connect those to one side of the injectors and the rest is the same on the writeup
Old 09-07-2008, 12:15 AM   #5
Hondaholic
prpprimo's Avatar
Ride:  91 hatch z6/ 98 coupe z7
Rep Power: 2 prpprimo is on a distinguished road
Send a message via AIM to prpprimo
ditch the resistor box if your using obd1 injectors as these are high impedance. add 4 wires from the engine harness to the ecu through the fire wall...Be sure to utilize a 4pin plug (quick disconnect)for future removal.
prpprimo is online now   Reply With Quote
Old 09-07-2008, 11:46 PM   #6
Hondaholic
prpprimo's Avatar
oh yeh...and shield your diz wires....
Forum Jump
DPFI to MPFI dizzy question blackice90HB HYBRID -> ED-EF / DA 1 11-04-2005 09:08 PM
DPFI to MPFI... George777 ECU's, Electronics, and Tuning 2 10-05-2005 11:48 AM
sorry old question: dpfi->mpfi conversion misfits_skater HYBRID -> ED-EF / DA 3 08-25-2005 07:10 PM
Question about DPFI to MPFI Drake HYBRID -> ED-EF / DA 12 05-05-2004 10:04 AM
Quick Dpfi To Mpfi Question. AlwaysMovin HYBRID -> EG-EK / DC 1 02-18-2003 11:12 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
