| | LinkBack | Thread Tools |
| | #1 |
| Senior Member Join Date: Mar 2008 Location: miami,fl Age: 21
iTrader: 0 / 0% Ride: 95 honda civic (gsr)
Rep Power: 7 | |
| | #5 |
| Brutal Moderator Join Date: Jun 2006 Location: Rochester Hills, MI Age: 26
iTrader: 0 / 0% Ride: 97 Integra LS Coupe
Rep Power: 246 | Uhhh...as far as I know there was no D15 VTEC in 96...and I hope you're going for gas mileage rather than performance, because you're never gonna be fast with that turd of a transmission... |
| | #6 |
Rep Power: 7 | yeh me either, one of the guy who sold the motor he said he got d15b vtec.. which mean the motor got vtec on the head with d15b block i guess so. but i am not gunna use that motor for race. just for chill on the street but i want to know if p28 ecu will work on d15b vtec engine ? |
| | #7 |
Rep Power: 246 | Yes, the P28 will work assuming the motor's OBD1. If it really is a true D15B VTEC it came from a 92-95 rather than a 96. If it's some kind of Mini-Me using a 1.5 block but a newer head, then you're going to need an ECU compatible with whatever OBD system you're using. |
| | #8 | |
Rep Power: 7 | Quote:
| | #11 | |
| you get the BRAKE | Quote:
1) your car is obd2a 2) a p28 is for obd1 3) you will have to buy a jumper harness (obd2a - obd1) 4) you must use an obd1 distributor 5) you have to use the proper p28. If your manual transaxle, than you will need a 5speed p28. If your automatic, you will need a p28 from an automatic. | |
| | #12 | |
| | #15 | |
Rep Power: 246 | Quote:
| | #16 | |
