Signal Light / Temp Problem
Old 05-12-2003, 10:26 PM   #1
Rep Power: 16 starboy869 is off the scale
Thumbs up
Hi,
Ok.. I'm at a lost.
I'm having a problem with my signal light & temp gauge.
Most of the time ONLY when I'm moving (even 1 kph) & when I have my signal light on in either direction my temp gauge will move up & down with the flash.
This doesn't happen when I'm at a full stop.
I've added a missing ground wire from the valve cover to the frame. This fixed the dash signal from going dim. What gage of wire should this wire be?
Also I changed out my neg. battery cable with no luck regarding the problem.
Any ideas? I'm still banking on a bad ground.
Chris
2000 Civic SiR
CFB Petawawa, ON
Canada
starboy869 is offline   Reply With Quote
Old 05-13-2003, 03:12 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
as am i.
check your fuse boxes for any hanging wires, or croseed wires.
also, check light bulbs. some bulbs have dual filiments... and if one brakes, and crosses onto the other, its been knon to cause wacked out results.
Dash light problem Blanco ECU's, Electronics, and Tuning 7 08-10-2004 02:03 AM
Help! Tail Light Problem integrator ECU's, Electronics, and Tuning 4 10-15-2003 01:47 PM
Coolant Temp Sensor Light EKDRIFTER ECU's, Electronics, and Tuning 10 07-28-2003 02:54 AM
Chek Engine Light Problem red95solsi General Tech and Maintenance 2 05-17-2003 02:07 AM
Wtb 92-95 Del Sol Front Signal Light monzee Parts: For Sale/Trade/Wanted 1 04-09-2003 01:44 AM
