speedo cable broke,
Old 07-03-2009, 05:12 PM   #1
Greenhorn
Rep Power: 0 MissMyDA is on a distinguished road
Default speedo cable broke,
Hi guys, so yesterday I just traded my LS-V DA for this 90 EF with a 89 b16a / S1 cable trany / OBD0 pr-3 ecu, the car had CEL:
#1 (O2 sensor defect)
#10 (IAT defect)
#23 (KS defect)
the thing ran like a champ though. This morning im driving, and I lost my speedo and vtec stopped cracking, found speedo cable broken about 2" behind cluster, add CEL # 17 (VSS defect)
Question 1: What doner cars / years can I pull a speedometer cable?
Question 2: Speedo affects vtec how? I have searched and seen some b.s. about ecu must read speed over 15-20mph, or ecu thinks your free spinning engine. But my buddys crx w/ same set up (OBD1 ecu though) hit vtec w/o speedo cable and his CEL was on. Vtec requires oil temp, oil pressure and a tach signal... Does anyone know if analog vss or electric vss has any difference as far as ecu controlling vtec?
MissMyDA is offline   Reply With Quote
Speedo cable C-Bye General Tech and Maintenance 8 10-19-2008 11:05 PM
Speedo Cable FamilyD General Tech and Maintenance 1 03-14-2004 09:53 PM
Which Speedo Cable? inspecta83 General Tech and Maintenance 4 04-02-2003 07:13 AM
Speedo Cable GSRCRXsi General Tech and Maintenance 3 02-17-2003 06:52 PM
Speedo Cable Help! GSRCRXsi General Tech and Maintenance 1 01-28-2003 05:12 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
