Speedometer & Odometer not working.
Old 07-26-2006, 05:59 PM   #1
Rep Power: 0 95preludesi is on a distinguished road
Default Speedometer & Odometer not working.
Hey guys, I just recently purchased an automatic 95 Prelude SI (great car, runs strong). However the only discrepancy that I have is that the Speedometer and the Odometer are not working in the car. RPM's work fine but speedometer and odometer have never worked.
So far I have already replaced the VSS (the one on top of the tranny) with a new Honda one. I have replaced the guage cluster as well (thought that might be the problem since my old guage cluster didn't emit a light when it was in D4).
I have also checked the fuse (no.23) as well and even replaced it with a new one and still no go.
I did notice that when I replaced the gauge cluster with a used one, the D4 light works but when I am driving it blinks at me. The car also throws a CEL after about 10 minutes of driving, and I threw in a jumper cable and found that it was reading a code 17 (1 long flash followed by 7 short flashes).
I also noticed that when I reached behind the center console I found 2 blue wires (1 of the blue wires was for the diagnostic connector) and 1 yellow wire. As well as 2 connectors. Anybody know what these wires are and why they are unplugged? I have included pictures as well.
http://i102.photobucket.com/albums/m87/95p...si/DSC05285.jpg
http://i102.photobucket.com/albums/m87/95p...si/DSC05283.jpg
Anyway, since this car has no speedometer cable, is there anything that I am overlooking that could be the culprit of my speedometer and odometer to not work?
The only other thing I can think of is that the lower part of the VSS that resides inside the transmission might be messed up. If thats the case, do I have to drop the transmission to take out the lower part of the VSS? I am really hoping this is a simple problem since this car has already been a PITA since day 1.
95preludesi is offline   Reply With Quote
Old 08-01-2006, 10:12 AM   #2
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
which part of the VSS did you replace?
code 17 = VSS
i would get a helms manual and follow their diagnostic procedures to determine exactly whats causing the problem
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
88 prelude speedometer not working 88preludeanth Prelude 3 08-07-2006 06:50 PM
Speedometer not working lude9593 General Tech and Maintenance 15 03-12-2005 03:27 PM
RPM SPEEDOMETER NOT WORKING 96EXTO2000SI General Tech and Maintenance 1 08-06-2004 01:48 PM
The latest GS-R find UDT General Tech and Maintenance 24 04-01-2004 01:20 AM
am i hitting vtec if my speedometer is not working delsol97sir HYBRID -> ED-EF / DA 1 07-22-2003 11:47 PM
