Swapping a B17A to a B16A G2 wondering about ECU'S
Old 07-16-2008, 12:41 AM   #1
Rep Power: 0 J3r3my590 is on a distinguished road
Default Swapping a B17A to a B16A G2 wondering about ECU'S
Hello all, just a few questions, i currently have a B17A in my 1992 GSR however iam swapping it with a B16A G2 SIR II. i kno that everything will fit as far as motor mounts, stock YS1 tranny and stuff, im just wondering if my stock P61 ECU will work with the new engine or do i need the B16's stock ECU being the P30? both are capable of handling VTEC. just wondering if they will work with eachother, or if there is a better match or other options i can do....?
i believe from my understanding everything is the same, and it will work however the fuel timming and vtec's engaging RPM will be different using the P61 ECU (from the B17a). i also hear that im better off getting a P72 ECU to use with my swap... either way im a little confused and would like to know wat would work, wat would work better and your opinions on it... maybe gettting it chipped or hondata is better or easier... let me know!
thanks
J3r3my590 is offline   Reply With Quote
Old 07-16-2008, 03:12 PM   #2
B
Administrator
B's Avatar
Ride:  m3, dakota
Rep Power: 157 B has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace
your stock p61 ecu will work... but it won't be perfect, as its designed for the gsr motor, not the si motor. i dont know what those gsr's are (obd 0 or 1) but your probably best off with that gen pr3 or p30 (b16 ecus, depending on obd)
B is offline   Reply With Quote
Old 07-16-2008, 03:14 PM   #3
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 160 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
there obd1
Forum Jump
Jdm Integra Cluster Da5 Da6 B16a 90-93 Da Xsi Gsr B17a RSS-Bot Auctions 0 12-03-2007 09:43 PM
WONDERING? B16A OR B18A1??? 91jdmteg HYBRID -> ED-EF / DA 29 09-26-2005 10:18 AM
b17a vs b16a h1coupe Engine Building 18 12-22-2003 10:57 AM
swapping b16a sir 2 into 95civic hb dx sbcsam HYBRID -> EG-EK / DC 6 10-31-2003 08:32 PM
Swapping JDM B16A into a 92 Integra robbz23 HYBRID -> EG-EK / DC 21 10-20-2003 05:46 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
