I have a 97 ITR motor. In a 92 SI EG.
I just bought a ECU from phearable.net now im getting a CEL. It is 22 so it is VTEC OIL PRESS. Now when i was running my OBDII P73 It had no CEL why would that be? What can be causing this to happen? __________________
-92 civic w/ 97 B18C-R I/H/E traction bar 13.893@ 98.52mph -95 LS Integra I/H Beater car (Rear ended RIP) 15.62@ 86.27 -00 Civic Si I (my DD) b16 SiR-II swap |
HS Troll...And Mod
Ride: 2001 Honda S2000
EG...umm did you wire the VTEC?
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
#4 | |
I was googling in and found a guy with the same prob http://www.honda-acura.net/forums/archive/...hp/t-82941.html is this what your talking about. __________________
#5 |
I am thinking of taping the VTEC press wire. with the VTEC sensor wire, but where is the VTEC press wire located.
Would i tap in the VTS and run a wire to the Civic ECU harness? Is this even a good option? __________________
#6 |
HS Troll...And Mod
well it would give it sensor input and i think i heard of someone doing something similar...
I should probably stick to prelude/h22 questions. __________________
#8 | |
I do have a Hondata system so I could disable it that way, but I dont have the option of doing dataloging my self, I was going to have a shop tune me so I didnt get the option. I dont want to go to a shop just for this, I'm saving money for dyno time and proper tune. but i dont want to wait for a month to use this ecu. Back to the wiring if I just tap the VTEC press wire (mine has one wire) down to the sensor below (if that is the press. sensor) would that do the trick. I found this by doing a search. so im guessing that is were the press wire can be loccated at. http://www.hondaswap.com/forums/index.php?...topic=50364&hl= __________________
#9 | |
[post=]Quoted post[/post] [/b][/quote]And if you have hondata its as easy as clicking on a box. You just need a chip burner to make new chip. I wouldn't be worried about shipping on a new chip from phearable either, its like 5 bux. __________________
97 ex coupe Wire tuck in progress.... |
#10 |
I dont have the option of doing anything with my s200 system, every thing has to be done by a dealer
, I just got the base system for 200 bucks, it had no chiping kit that is why I had Vega do it. I wish i paid the extra to do my own base maps I think im just going to tap it. Now is the press sensor directly under the VTEC sensor green plug on the side of the block(dizzy side) on my B18C? I see two wires (rd/wt, grn,blk) on the bottom plug im guessing one is the ground. So is this the correct place where I'm going to tap it? Or should I tap the VTEC sensor and feed the wire to my civic harness, for the correct pin on my ecu, so it sees Volts? If this is doesnt work for me, I will just wait a month try to get some cams and dyno time and have some one tune it for me, and disable the switch for me. __________________
#11 |
RETIRED
ask him to email you the bin file... shouldn't be a problem.
i have hondata and can re-burn you the map with that disabled for 15 bucks if he won't do it. |
#12 | |
#13 |
I just wired it by combinding the D6 wire with the A4 wire. VTEC kicks in and feels like it stays in but I got a CEL. CEL does not come on until high rpms, even that it may take all the way to 4 gear and that is pulling to about 8K per gear. Tried to pull the code but just got one long blink, I dont think it is a Code ten witch is Air Intake temp.
What fuse do I pull in my 92 Civic (the diagram on the fuse box cam off) so i could reset the ecu. __________________
#14 |
HS Troll...And Mod
i thought it was the dash and clock fuse under the hood. usually i just pull the negative battery cable.
