TPS code with B18c OBD-1 swap!!
Old 07-26-2004, 09:42 PM   #1
Rep Power: 13 The WORLD is yours... is off the scale
well, 1st off my tps was off the gsr TB when i got the engine. so i put it back on without the gasket. and i did put it on right. so i try to set the tps to the spec volt readings. and all i can get is 0.01 to 0.08, then a 4.97 all at closed throttle. then i get 0.01 to 0.08, then 2.97 all at WOT. those are not the right readings!!
how i'm testing my tps:
i'm taking my red lead and poking it in the middle(red) wire on the tps. and then grounding the black lead to the engine. with the ignition(spelling?) turn'd on. but not running.
i've comfirm'd that my obd0-obd1 conv. harness tps wire is located in the right slots!!
i even have changed the tps from a known working tps. and i still have this problem!!
any help here would be the great!!
thanks
~InstiGatoR~ 89 CRX si B18c JDM GSR, 90 ls tranny, exedy racing clutch kit, ACT pro lite 8.8lbs aluminum flywheel, victor X IM, short ram intake, 90 ls header, greddy SP2 cat-back exhaust, skunk2 adj. cam gears, B&M F.P.R and F.P.G, Hasport Billet mounts, OBD1 convert'd, chipp'd P72 ecu using Uberdata, H&R racing springs, tokico Blue's, DC sport short shifter, DC sport front and rear strut bars. install'd my zex dry kit!!
soon i'll be putting on my WW rs body kit. customizing a FG hood for my engine. going turbo(maybe/maybe not). datalogging with Uberdata. the list goes on!
The WORLD is yours... is offline   Reply With Quote
Old 07-27-2004, 09:46 AM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
try checking the voltage at the ECU , rather than jamming the lead into the TPS.
pills_PMD is offline   Reply With Quote
Old 07-27-2004, 02:44 PM   #3
ok i'll try that. but then i'll need a friend to be at the tps. moving it just so. to get the correct dial in!!
i'll see what i can do.
thanks
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
