VAFC Controller bypass engine code?
Old 12-04-2006, 09:41 PM   #1
Rep Power: 11 kylelohrenz is off the scale
Default VAFC Controller bypass engine code?
Hey guys,
I have been having trouble with a OBD1 b16 engaging vtec. As soon as it throws a 36 code (JDM traction control is all I have found about the code) vtec will not engage. No other codes are present but as soon as I clear this 36 code, vtech works through 1rst gear until it throws the 36 code again. Will a VAFC bypass this problem? I am under the impression that the VAFC will allow me to adjust the RPM at which the vtec engages so it is not relying on the ECU in any way to vtec, only the engine sensors. Is this correct? Thanks for any info on the possible bypass or code 36!
kylelohrenz is offline   Reply With Quote
Old 12-05-2006, 11:33 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
As far as I know 36 is not a valid code. Is that ECU chipped? Try a friend's P30 or something to see if the ECU itself is the problem or not.
The VAFC will bypass the need for the VTEC Pressure Switch so VTEC will engage but the ECU still controls the redline. So if that weird code is making the car not rev to 8200 like it's suppose to, then you're still screwed.
Plus, the VAFC will only band-aid your problem, you got bigger problems if your ECU is throwing an invalid code and it needs to be fixed. JDM traction control? Never knew a code was dependent on it's country lol
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 12-05-2006, 08:43 PM   #3
Thanks for the reply. I had the same code on my race civic with another P30 ECU. Neither ECU is chipped. The 36 code info that I have found designates a "traction control found only on JDM ECU's. I never did figure out the 36 code on my race civic. Sometimes it would throw it and sometimes it wouldn't. I guess I could just have two messed up ECU's but man that seems far fetched. Thanks for the info!
Old 12-06-2006, 02:13 PM   #4
I'll be back...
No problem. You can always run a stock P28 and see what happens. Then if the P28 throws no codes and acts normal then take the P28 and tune that son bitch with crome or uberdata.
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
Check Engine Light. Ecu Throwing A Code igotsol! ECU's, Electronics, and Tuning 1 02-16-2003 02:31 AM
1986 Honda Prelude Engine Code? jamied642 Members' Lounge 2 02-05-2003 09:32 PM
Engine Code Help theguyonthecouch HYBRID -> EG-EK / DC 6 01-12-2003 03:07 PM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
