This is a discussion on Vtec point? in the ECU's, Electronics, and Tuning forum
Hey, quick question I need answered by tomorrow...
What is the best spot without extensive tuning To set the vtec point at for N/A? Some sites say 4500, some 4800, some 5000 and others 5500.
I was thinking 5k, but I just want a solid ...
| | #1 |
| Hey, quick question I need answered by tomorrow... What is the best spot without extensive tuning To set the vtec point at for N/A? Some sites say 4500, some 4800, some 5000 and others 5500. I was thinking 5k, but I just want a solid answer first. Lemme know, thanks. |
| | #2 | |
| Quote:
| | #3 |
| Ya I'm not throwing it on the dyno until I go boost, this was just to get the p08 basemaps and I figured since the vtec point was customizable yhere might be a "range" I could set it too in order to maximize effect. Still time left, somebody chime innnnn |
| | #4 |
| it depends on your setup... Most stock or mildly modified B16 engines about 5500 is good. Gsr with sk2 manifold around the same, B20 around 5200..... |
| | #5 | |
| Quote:
IN MY OPINION - The best way is to do a pull on the low lobes, then one on the high lobe( set VTEC around 3k) Then, set VTEC where the torque curve of the two graphs intersect. Usually after playing with cam timing/overlap, you can get the low cams to gain torque for several hundred RPM further, then raise the VTEC point
__________________ www.hamotorsports.com Supplier of Honda/ Acura Engine Swap Mounts, Axles, and much more! | |
| | #6 |
| K I'll just keep it at 5500rpm, 300 down from stock engagement. |
| | #7 |
| | #8 |
| 5 k is good but dont go any lower that would be stupid. 5 k or higher. |
Similar Threads | ||||
| dual point to multi point conversion.. problems | str8jdmswap | HYBRID -> ED-EF / DA | 2 | 02-15-2010 09:18 PM |
| dual point to sohc vtec | od_civic | HYBRID -> ED-EF / DA | 1 | 02-11-2008 09:04 PM |
| WTB: dual point 91 crx vtec head and turbo kit | demonboy1300 | Parts: For Sale/Trade/Wanted | 1 | 10-23-2007 04:31 PM |
| what is the stock vtec activation point for h22a1 | turbowagon92 | ECU's, Electronics, and Tuning | 1 | 05-14-2007 11:18 AM |
| Vtec Killing Cams, What Is The Point? | MaaseyRacer | General Tech and Maintenance | 3 | 03-24-2003 10:33 PM |
