vtec problem????
Old 04-11-2008, 07:20 PM   #1
Rep Power: 0 General Lee is infamous around these partsGeneral Lee is infamous around these parts
Default vtec problem????
im wondering y my vtec oil pressure switch will not engage, my vtec will work if i hard wire it and ive replaced the oil pressure switch and still no vtec, could it be a problem with my ecu jumper or is it the wiring harness? its for a 99'-00' B16A in my 00' acura el. if you have any ideas or ways to trouble shoot please help!!
General Lee is offline   Reply With Quote
Old 04-11-2008, 08:15 PM   #2
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
Rep Power: 46 YBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to beholdYBLEGAL is a splendid one to behold
myspace
why'd you call it an SiR motor in your other post?
Old 04-12-2008, 12:25 AM   #3
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 160 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
it could but the first thing you should check is to see if your low on oil
AHHVTEC is online now   Reply With Quote
Old 04-13-2008, 12:29 AM   #4
because its a jdm b16a in my 2000 acura 1.6EL, i call it my acura SiR
Old 04-13-2008, 12:31 AM   #5
my oil is level is good, i wish that was all it was lol! any other ideas???
Old 04-13-2008, 02:35 AM   #6
YBLEGAL's Avatar
myspace
well is the B16 OBD0, OBD1, or OBD2? j/w. not common for OBD1 in an OBD2 chassis. tho that's what i own.
Old 04-13-2008, 10:39 PM   #7
its 99' civic sir motor with obd2a ecu
Old 04-13-2008, 10:42 PM   #8
YBLEGAL's Avatar
myspace
hmm you must not be from the USA.. or are you? what country are you in?
Old 04-13-2008, 11:11 PM   #9
ya im from canada i bought a 2000 acura EL1.6 which is only available in canada it is the same as a honda domani in japan. I bought a 99' b16a that i think runs on obd2 but the wiring harness i had was from the original D16A2 vtec, i bought an ecu that i believe is called an 0BD2A i think its for the 00' or newer wiring harness, because my original ecu was a obd2a but it was for the d16a2
Old 04-13-2008, 11:24 PM   #10
sorry accually i think it might be a d16y8 was the original motor
Old 04-14-2008, 04:38 PM   #11
Banned
Rep Power: 0 OKCZombie is on a distinguished road
okay y8 harness should work - you would want to make sure you had the right ecu for that motor. Are you throwing any CEL's? Both Vtec plugs for oil pressure and vtec solenoid connected?
OKCZombie is offline   Reply With Quote
Old 04-14-2008, 07:57 PM   #12
JDM Matt
Ride:  Honda EP3 K20A2
Rep Power: 0 jdmep3 is on a distinguished road
myspace
Default Your v-tec will work if.....
Your Vtec will work if,
You get the engine's ecu, and!! look in a hanes manual to find which plug on the ecu is v-tec. Odds are, there is not a wire in that hole, on the plug. Put a wire in there, and run the wire to the v-tec solinoid, also do the same with the oil pressure switch, you prob don't have v-tec wired up, just try this.
jdmep3 is offline   Reply With Quote
Old 04-14-2008, 10:22 PM   #13
YBLEGAL's Avatar
myspace
hey jdmep3...your mom has vtec. stop being a noob. learn.
to all the noobs. use the reference section! it's too easy, you woulda had this figured out long ago. here! -
http://hondaswap.com/attachments/11d...4249-obd2a.jpg
ECU Pinouts
Reference Materials - HondaSwap Forums < it's even the top sticky!
do it! best of luck.
Old 04-14-2008, 11:53 PM   #14
ok i looked at the diagrams you posted, thank you, and it looks like i have the 96'-98' ecu but im running a Frog Engine Controls harness adapter for obd2b to obd2a harness, the adapter is good but im wondering if my harness didnt get hacked during the install so from what i understand is that i can run a wire from the apropriate spot on the adapter to the vtec selinoid itself, im also wondering if i should try to run both a oil pressure switch wire and a selinoid wire, because a tested the seleniod and it has power my vtec just wont engage at 5500rpm
Old 04-15-2008, 12:01 AM   #15
yes every plug on the seleniod is connected and it is the right ecu for the motor the only thing thats miss matched is the harness its the original y8
Old 07-18-2008, 09:28 PM   #16
GREAT NEWS- V-TEC- Holy Sh*t its awesome!!! after lots of head scratching and part changing I've got v-tec. A year ago I installed a B16A from japan in to my 00' Acura 1.6EL, the engine went in smoothly but v-tec has been a problem from the beggining. took everyones advice, replaced the oil pressure switch, cleaned out the soleniod and checked all the wires but everything was good anyway I drove it for a while with no v-tec then I noticed the idle was getting higher and higher so I checked the TPS and realized it was loose so I tightend it and set the idle and BAM!! vtec worked I think it was not working because the ecu was sensing that the engine was running lean. No one ever mentioned that to me so I hope maybe this helps someone else in the future.
P.S. To the guy in the 5.0 Mustang...... HAHA Sucker!!!!!
Old 08-07-2008, 03:37 AM   #17
Banned
Ride:  89 Civic Hatch
Rep Power: 0 TravisCadello is infamous around these partsTravisCadello is infamous around these partsTravisCadello is infamous around these parts
myspace
Lol, Thats Good to hear, its crazy something that little will cause a problem like that.
TravisCadello is offline   Reply With Quote
Old 08-21-2008, 12:07 AM   #18
Rep Power: 0 ~blueeg6~ is on a distinguished road
do u have ur check engine light on..?? cus u may have a auto ecu.. u should chip ur ecu.. sometimes some ecus lok for a sensor.. wich some engines dont have.. but the best thing is to chip ur ecu..
~blueeg6~ is offline   Reply With Quote
Old 08-21-2008, 12:45 AM   #19
Resident Fat Ass
George777's Avatar
Ride:  90 Hatch, 91 Rex, 85 Yamaha Virago, 82 CB900F Supersport
Rep Power: 58 George777 has a brilliant future
check the thread date man. and he got it working.
Originally Posted by Blanco View Post
Eat shit and fucking die you ignorant redneck.
Originally Posted by B16RacerN2NR View Post
I don't know how to do plastic surgery but I love titties, you don't see me trying to go around giving breast implants do you?
Originally Posted by phyregod View Post
Yup, Its sex on wheels. Violent, vigorous sex. With a super model. Scratch that, super model twins.
George777 is offline   Reply With Quote
Old 08-31-2008, 11:12 PM   #20
Rep Power: 0 toughlikerock is on a distinguished road
Default vtec
hi im wondering why my my car won't gas. i hooked up the vtec and pressure switch. when i turn the car on it runs, but when i gas it, it dies out? why is that? can you help me out?
toughlikerock is offline   Reply With Quote
Old 08-31-2008, 11:13 PM   #21
i have a 90 crx with a 95 sohc vtec engine. it it the throttle wires?
Old 08-31-2008, 11:18 PM   #22
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 134 BrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Start your own thread please. Don't hijack somebody else's...
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 09-29-2008, 04:54 PM   #23
Rep Power: 0 d-paul14 is on a distinguished road
Wink Which cylinder head does my engine have
I just bought a 1992 hatch with a integra ls block converted to V-tec. I am not sure what cylinder head is on it. The block engine code is B18b1 and the head is stamped with a PR3-2 or PR3-1. It currently has a JDM type-r intake manifold and cams. I am interested in either buying different cams or an intake manifold but I'm not sure about the cylinder head!
d-paul14 is offline   Reply With Quote
Old 09-29-2008, 07:16 PM   #24
YBLEGAL's Avatar
myspace
Thumbs down
Like the post above you, start your own thread!!! What your asking doesn't even pertain to the topic of this thread....
Go here: Engine Building - HondaSwap Forums
Click 'New Thread'
Noob!
YBLEGAL.NET ProfileProjectsParts For SaleSteel Braided Brake Lines • Front Camber Kit (Price Drop) • Manual Brake Pedal
Old 10-04-2008, 05:17 PM   #25
Rep Power: 0 jonocivic69 is on a distinguished road
helo, new to this site, but would appreciate some advice? i recently changed the distributor in my eg5 civic vti but hapnd to snap off the green connector to what i think is the vtec solenoid during the process...and since then i can not go above 3,500 rpm. she hits 3,500 rpm like a limiter and wont go above it in any gear which limits me to a top speed of 65mph and a very boring drive every day. would like some advice as to what the problem is?
jonocivic69 is offline   Reply With Quote
