vtec problem...????
Old 05-18-2008, 01:41 PM   #1
Rep Power: 0 capzzz is on a distinguished road
Default vtec problem...????
i just bought a 93 hatch swapped with a si motor.....now the vtec wasnt working..... brought it in 2 a buddys shop....got a computer pretty shure its p28 chipped not 2 shure....and he hooked up my vtec cause the wires wernt there be4... drove it for 3 weeks and it worked fine....so now when i drive it.....and i hit the vtec......when i slow down the engine light comes on.....but it feels liek the vtec is stuck on.... liek it pulllsssss wayyyy more..... any help 2 what the problem is.... thnx..n again im not 2 much of the car guy thnx
capzzz is offline   Reply With Quote
Old 05-18-2008, 02:09 PM   #2
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Is the check engine light on?
PSN Network ID: BrutalB83
Old 05-18-2008, 02:13 PM   #3
yes it on after i hit the vtec........but if i drive it normal and dont hit the vtec its goood... no light .......even if i turn the car off and turn it back on the cheack engine light goes away untill i hit vtec again....
Old 05-18-2008, 02:34 PM   #4
Brutal Moderator
BrutalB83's Avatar
myspace
Well I'd take it somewhere and get it diagnosed then (or do it yourself if you know how). It sounds like the car might be in limp mode. The quickest way to figure out what's wrong with it though, is to get the warning light diagnosed...
Old 05-18-2008, 02:43 PM   #5
what do you mean bye limp mode....and not 2 mention......when the engine light is on.... it feels liek the vtec is stlll on.....liek the ca pullss hard....but when the vtec kickes in......it boggles liek chokes...
Old 05-19-2008, 11:46 PM   #6
Drive and Ride A Honda
Ride:  Civic Hatch
Rep Power: 5 svaby will become famous soon enough
dang thats weird... maybe the wiring to the oil pressure switch or somthing is messed up
svaby is offline   Reply With Quote
Old 05-21-2008, 12:20 AM   #7
Brutal Moderator
BrutalB83's Avatar
myspace
When you get a check engine light the car will go into limp mode. This means that it won't let you rev past a certain point. That way, you won't hurt the engine until whatever is causing the check engine light to come on is fixed.
Like I said, if the light is on, then you need to get it diagnosed by a shop. Hell, just take it to Auto-Zone and have them use their scan tool on it if you don't want to pay a shop, or just read the article in the FAQ section on how to pull the codes yourself.
It could be any number of things causing the light, you really need to figure out what it is before you start messing with stuff...
Old 05-29-2008, 11:11 PM   #8
thnx..... it was the vtec oil pressure switch.....changed it..... and it still did it....brought it back 2 the shop..... and and the said it might be a bad ground wire somewhere. changed all the grounds and its all perfect thnx
99 ek with ls vtec problem solobomber HYBRID -> EG-EK / DC 6 03-13-2008 12:34 AM
Vtec Problem Spinal General Tech and Maintenance 12 01-25-2008 11:15 AM
vtec problem , did almost everything redcivic_eg6 General Tech and Maintenance 8 11-18-2005 09:44 PM
vtec problem please help 93vicb16a2 HYBRID -> EG-EK / DC 23 09-04-2005 01:03 PM
vtec problem... hybridracer504 HYBRID -> EG-EK / DC 8 11-19-2003 05:01 PM
