Facebook Twitter
wtf does a resistor box do?
This is a discussion on wtf does a resistor box do? in the ECU's, Electronics, and Tuning forum
hey i have a 92 jdm h22a and my mechanic tells me im supposed to have a resistor box. all i know is that its for the injectors. does it regulate the voltage or something? what is it and what exactly does it do. i ...
Old 01-05-2004, 07:14 PM   #1
hey i have a 92 jdm h22a and my mechanic tells me im supposed to have a resistor box. all i know is that its for the injectors. does it regulate the voltage or something? what is it and what exactly does it do. i dont have one and my car ran great.
H22AdelSol is offline   Reply With Quote
Old 01-05-2004, 10:59 PM   #2
A resistor impedes the flow of current... i.e dissipates energy in the form of heat...
EDIT: I meant current, not voltage
jiahanhao is offline   Reply With Quote
Old 01-05-2004, 11:32 PM   #3
and that does what to my injectors?
Old 01-05-2004, 11:40 PM   #4
pissedoffsol's Avatar
it has nothing to do with voltage. it deals with ohms, or in low-mans terms, resistance.
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 280cc
it really depends on the ecu... as that is what you are "impeding"
for the most part,
Peak and hold style require a resistor box.
saturated, do not
im not sure how it holds out for the preludes though... i know civics
Old 01-06-2004, 12:22 AM   #5
so not having it would not just fry my computer right, it would only make it run better.
Old 01-06-2004, 02:06 AM   #6
no, it will fry the ecu. lol
Old 01-06-2004, 02:56 AM   #7
MikeBergy's Avatar
Since the injectors are basically solenoids operating a valve to let fuel into the combustion chamber, I would guess that technically a resistor box is making the solenoid operate at the correct current flow . This current causes a magnetic feild (i.e. electromagnet) and allows the valve to open. I would think if you passed too much current to the solenoids in the injectors, you would fry your injectors before anything happened to your ecu. From what it sounds like, your car probably already had resistors hardwired into the system. Did you get oem or aftermarket injectors? OEM shouldn't require any resistor boxes, they should plug right in. If you got some gnarly Accel or MSD injectors that were peak-hold type injectors, and you didn't put a resistor box in to keep them at the right current, you would probably have fried the injectors the first time to started the car, or shortly thereafter, then the car wouldn't start. I'm taking this in a purely theoretical direction, since I've never ripped apart any injectors, nor do I have a bunch of specs for any.
2002 VW GTI 337 Edition - me love turbo
1991 Integra - hanging out in the garage....
RIP 2005 Red Yamaha R6
MikeBergy is offline   Reply With Quote
Old 01-06-2004, 10:11 AM   #8
Originally posted by MikeBergy@Jan 6 2004, 03:56 AM
[b] I would think if you passed too much current to the solenoids in the injectors, you would fry your injectors before anything happened to your ecu.
nope- it goes the other way...
the injectors send the signal back to the ecu, and thus if its too high, it fries the computer.
Old 01-06-2004, 10:32 AM   #9
Mike's right.
The resistor box controls the amount of current that the injectors draw in order for them to operate correctly.
Almost all Honda ECUs from 88- present are setup to run saturated injectors. Saturated injectors are "high impedance" injectors. Saturated injectors are a newer technology than Peak+Hold injectors. Peak and Hold injectors require a MUCH beefier driver unit in order to work correctly - you are supposed to fire a "peak" current at the injector to slam it open, then drop the current down to a lower level and "hold" it until you want the injector to close, then drop to zero. Saturated injectors only require a single "open" current level to properly function. Back in 1988 when honda's design team started on the OBD0 cars, there wasn't a Saturated injector in the size they wanted from the manufacturer they are in bed with (Nippon Denso). So, instead of putting in P+H drivers, they added a resistor box to change the loading on the saturated drivers so the drivers wouldn't cook themselves with the P+H injectors. The resistor box is a HACK. Plain and fucking simple. Take an oscilloscope to the injectors themselves on a car with a resistor box and compare it to a car where there are true P+H drivers, and you'll be scared. The whole "peak" and hold thing isn't really happening. What this means in real world terms is that the base pulse width (smallest amount of fuel the injector can deliver) increases greatly because the injector takes longer to open compared to being driven with a proper P+H driver. What this means for you is that there is a more finite limit to the size of injector you can put in the car (~1000cc vs ~2500cc) when using a P+H injector and a resistor box becuase of the driver issues.
And as to this gentleman's specific question, 92-96 H22A Preludes came with 310CC P+H injectors (unlike the 240cc used elsewhere in the fleet) presumably because the 290cc saturated injectors used in 97-01 preludes were not available/cheap enough yet. YOU NEED THE RESISTOR BOX OR SHIT WILL FRY.
PGMFI.org founder and DIY ECU tuning advocate
Just say no to rice...
radnulb is offline   Reply With Quote
Old 01-07-2004, 12:27 AM   #10
Originally posted by pissedoffsol@Jan 6 2004, 12:40 AM
[b] it has nothing to do with voltage. it deals with ohms, or in low-mans terms, resistance.
for the most part,
saturated, do not
What do you mean resistance has nothing to do with voltage?
V=IR, therefore R = V/I, voltage over current...
Old 01-07-2004, 12:41 AM   #11
hold on let me go get my physical science book from my freshman year of high school.
NotUrAverage_Si is offline   Reply With Quote
Old 01-07-2004, 12:47 AM   #12
MikeBergy's Avatar
Originally posted by NotUrAverage_Si@Jan 6 2004, 10:41 PM
[b] hold on let me go get my physical science book from my freshman year of high school.
apparently these books are the reference for understanding how an injector resistor box works. I look at the stupid book like 50 times a day trying to figure the darn things out....
Old 01-07-2004, 01:00 AM   #13
hah, I was just kidding though, it's been almost 8 years since I was a freshmen, theres no way I'd still have that book.
Old 01-07-2004, 01:10 AM   #14
MikeBergy's Avatar
lol, I'm smarter than those books now.
Old 01-07-2004, 09:37 PM   #15
lemme tell the story of my engine swap...
once upon a 4months ago my swap was running great. beating all kinda of cars at the track, then all of a sudden i find out from my mechanic that that main injector relay in the computer is fried and so is the injectors.
i get a new chipped p28 and it runs ok for a while, except that the injectors are almost fried. i put new RC injectors in and it runs great for like 5 passes and then they fry. i get a new wireharness cause mine was extended crappy and right when i put it in and put p28 in there, the ecu starts to fry instantly. my mechanic says he doesnt think i need a resistor box with the rc injectors.
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span>
Old 01-07-2004, 09:57 PM   #16
The answer seems obvious. install a resistor box. There are planty of websites to tell you how. It can be done cheaply with resistors from R shack if your in the DIY mood.
Canuck 93 Civic Si is offline   Reply With Quote
Old 01-07-2004, 10:02 PM   #17
Also in the articles section for ecu's it says the sensor grounds should be getting less than 1v and im getting about 5 if i stuck the multimeter pins in the right ones. i have alot of grounds to..
Old 01-08-2004, 10:24 AM   #18
ground issue would definately explain fried injectors.
READ Daniel-san.
RC make both Peak-n-Hold and Saturated injectors up to 550cc. Past 550cc, I believe ALL RCs are Peak-n-Hold. If you get saturated injectors, your mechanic is perfectly correct saying you don't need a resistor box.
Old 11-03-2006, 06:59 PM   #19
I know this is an old thread, but I was trying to find out if I needed a resistor box for a JDM h22a. It's going in a 97 sh-type prelude. The answer is: yes.
Much props to radnulb for the info. Sounds like you know your shit.
xxlegionsxx is offline   Reply With Quote
© 2001-2011 HondaSwap.com
a SkeyMedia network site | Advertise on Hondaswap.com
