SOMALIA
I have a ls/vtec and I'm building another block for boost.
So far I have a kms crank girdle ls crank/ acl race bearings/ gsr oil pickup / oil pump / oil pan. I'm going with eagle h beam rods. But for the pistons I was thinking of going with a 10:1 ratio.is that too high? I'm using a castiron manifold, with a t3/t4 intercooler built b16 head with port matched I.m. & gsr cams my power goal is around 350whp I have a p28 on chrome gold. Haven't picked up bigger in jectors fuel pump or rail yet.
1.9L LS/VTEC
I can't feel my face
Ride: 96 Civic - LS-T, 1989 Volvo 760
What are the exact specs of this "t3/t4"?
You can do it, but you will need a solid tune in order for it to remain reliable. |
#3 | |||
The Kicker of Elves.
No different that putting a turbo on a stock B16.
Don't misinterpret what I say. Quote:
#6 |
Boosted ls/vtec ohh yeah!
Ride: 2000 Civic Si, 1995 Civic Ex auto to manual conversion
You should make really good numbers with 8-10 psi. Like everyone else said just make sure you have someone tune it who knows what they are doing. Fuel management is one of the most important areas you can put your money.
I do swaps, engine builds, tuning, here in omaha. PM me for details. Do not PM me with tech questions, use the forums!! All motor ls/vtec build http://hondaswap.com/engine-building...53/#post791137 My 2000 civic si ls/vtec turbo build. http://hondaswap.com/engine-building...05/#post861900 |
#7 |
Ride: i have 14 cars i drive my sohc turbo ef
why sure some of the pro fwd cars are runing 13:1+ CR and like 40lbs of boost but i wouldnt recomend that with out being able to tune like a pro (well if you are trying that you beter be a pro) no 10:1 will do fine i tuned a stock gsr with a gt35 made 536hp at 17lbs on pump gas and went 11.20at136mph on his first run got kicked out of the track for no cage but he later cracked a sleve leading to total destruction like i warnd him about
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS. |
#8 | |||
^^^"Tune like a pro" and have a huge budget that allows you to rebuild the engine every 2-3 miles.
Unless you're building a purpose built drag car, leave that shit on the track.
#9 | |
yes this is true actuall they are lasting alot longer (well maby 5-8mi LOL) using aluminum rods the bigest problem is heads warping from crazy egts and 40+lbs boost
#10 | |
Its not like you were doing a favor. You can't expect 536 whp to last long at all on a stock GSR. |
#11 |
hey its his money and my work i told him before hand that it was not safe to do but it could be done and it will for sure break at some point you have just built a bomb
#13 |
if you install a blockguard you have to have the block rebored because it will distort the sleves
#14 |
Crusher of Noob Ambitions
Ride: 97 Integra LS Coupe
Did you bother to read any of the responses here? Boosting on a 10:1 ratio is just like boosting on a stock B16, so YES, IT WILL BE OK...
If you find something I say helpful, please rep it up! Also, DO NOT PM me with tech questions! Use the forums so we can all benefit from the answers. I will NOT respond to tech-related PMs... 97 Integra LS Coupe: *AEM Intake/Megan Header/Magnaflow Exhaust *Tokico Shocks & Springs *Megan Strut Braces & H-Brace *98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys) |
| carbon fiber air/fuel ratio gauge honda civic turbo | RSS-Bot | Auctions | 0 | 07-21-2008 07:50 PM |
| New- HALMETER AF30- Air/Fuel Ratio Gauge, Turbo, NA | RSS-Bot | Auctions | 0 | 03-23-2008 11:23 PM |
| apexi vafc2 II vtec controller air fuel ratio turbo | RSS-Bot | Auctions | 0 | 03-05-2008 07:53 PM |
| apexi vafc2 II vtec controller air fuel ratio turbo | RSS-Bot | Auctions | 0 | 02-26-2008 12:33 PM |
| rod ratio | scott | HYBRID -> EP / DC5 | 2 | 07-23-2003 11:21 PM |
