$3000 to spend
Old 10-20-2006, 02:36 AM   #1
Rep Power: 0 DerekW is on a distinguished road
Default $3000 to spend
Alright i just recently bought 99 hb runing the stock d16 motor with a t3/t4 turbo. its rather quick now, but going from my vr4 to this isnt gonna work. I have roughly 3000 to spend and i have access to a b18 block and b16. Will i have enough to build a boosted lsvtec, that is somewhat dependable that has atleast 350 to the wheels. Honda is all new to me so if you all dont mind please let me know what all i need to buy, stroke it or what. Also i can get machine work done rather cheap so if thats needed that is easily taken care of.
DerekW is offline   Reply With Quote
Old 10-20-2006, 02:37 AM   #2
b16 head by the way
Old 10-20-2006, 03:51 AM   #3
alterdcreations's Avatar
Rep Power: 10 alterdcreations is on a distinguished road
their are some people who would sleeve,add forged pistons and rods along with a ported head to that d16 and up the boost to 25 psi.
or get the 1.8 and build that
think before you start building
dont be scared to weld or machine parts
i try what i think works
experience is best when learned for yourself
unless it breaks the bank
RIP Nick Rella
you are missed already
alterdcreations is offline   Reply With Quote
Old 10-20-2006, 11:33 AM   #4
ef8
Rep Power: 10 ef8 is an unknown quantity at this point
Theres a guy that just made 405WHP on a Y8 with only Vitara pistons and Eagle rods.Stock sleeves and completely stock head.
ef8 is offline   Reply With Quote
Old 10-20-2006, 11:53 AM   #5
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Fro $3000, I would just build the LS motor for boost and call it a day. I wouldn't talk LSVTEC unless you have the ls block, b16 head, and $3000 left.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-20-2006, 12:03 PM   #6
ef8
LS is good for boost.Buy some rods,pistons,rod bolts,head studs,and piece together a turbo kit.This way you will still have money to go get a good tune.
Old 10-20-2006, 01:05 PM   #7
ls is a good buy. bigger displacment. $3000 is more than enough to get you up and running
RIP Nick Rella
Old 10-20-2006, 04:27 PM   #8
see the thing about it is. i can get th b16 head and the b18 block with virtually nohting in wither of them and have roughly 3000 to still spend on building the motor. I already have the turbo setup all ill need is a manifold to boost it.
what kinda valvetrain and bottom end should i buy to put it together
Old 10-20-2006, 05:03 PM   #9
didn't you say you get machine work for almost free???
you should sleeve, cp pistons(i would run 10 :1 or as close to factory compression as possible)eagle rods, and port that b16 head. use a victOr x (jg) manifold and throttle body. get bigger fuel injectors and other misillanous stuff along with a ecu management system and you will have a not to laggy fully capible trubo motor. after you max that t-3 then upgrade to whatever turbo can get you to your hp wishes.
Again this is only what i would do
RIP Nick Rella
Old 10-20-2006, 06:49 PM   #10
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
Rep Power: 35 erebunicrx is an unknown quantity at this point
Send a message via AIM to erebunicrx
if your only looking for 350 whp dont sleeve. buy pistons and rods and it will support that in any d/b series engine easily. i would stick with the motor thats in it, pistons and rods and the right tuning and have no problems.
03 mustang mach1, procharged, built motor, 6sp swap, built rear. 525whp @9psi
00 cbr 929rr 420 conversion -1 +2
erebunicrx is offline   Reply With Quote
OK, you have 12k to spend Battle Pope Members' Lounge 43 11-16-2004 10:20 PM
I have $14k to spend.... CarNub HYBRID -> EG-EK / DC 12 06-06-2004 07:23 PM
Imagine you have 20,000 to spend on a car... josh_isakson Members' Lounge 28 03-03-2004 02:59 AM
What to spend my tax return on? ef9civicgen4 Members' Lounge 15 01-17-2004 01:41 AM
I Have 12 Grand To Spend What Should I Do cobra96 HYBRID -> EG-EK / DC 1 04-20-2003 08:44 PM
