400 hp b18b build
Old 11-15-2006, 03:51 PM   #1
D Series FTL
spoolin@idle's Avatar
Ride:  1999 Accord EX Coupe - Daily
Rep Power: 7 spoolin@idle is on a distinguished road
Send a message via AIM to spoolin@idle
Default 400 hp b18b build
I'm halfway between a decent build and a budget build. I refuse to aim for that power mark on a stock bottom end... but I won't go "all out" and build something that is going to be capable of 600 hp when I don't plan on putting that down.
Starting out with a full B18B (no, not doing lsvtec)... this is my plan. I'm going to at least have the block hot tanked and surfaces decked, as well as having the cylinders posted. Cheaper alternative to sleeving it and I don't want to deal with the non-cooling issues that block guards can cause. I am thinking CP pistons, Eagle rods, ARP rod bolts, new seals and bearings obviously. MLS head gasket, ARP head studs, Crower cams, crower valvetrain, Ferrera valves, and of course, the head will recieve a PnP.
Some people are telling me "no just have the block sleeved". For those of you who DO actually know what posting is... please let me know if you fully agree with me in that 400 hp should be easily attainable with 9:1 compression, the build listed above, and say 18 - 20 psi through a GT35R.
spoolin@idle is offline   Reply With Quote
Old 11-15-2006, 03:55 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 177 reikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
looks like good choices. only thing i personally would change is the valves and springs. look into manley, they have some good prices. I cant find anyone who actively sells their parts for imports, but the guy in my sig can get them.
Your build is attainable. While you do have the posibility of blowing your engine (tuning will be the big cause of this), not sleeving will not be the reason the engine blows. Even if it does, buying another b18 block is still cheaper than sleeving.
Anime Informant
reikoshea is offline   Reply With Quote
Old 11-15-2006, 04:09 PM   #3
D Series FTL
Tuning is not an issue. Myself and my roommate both know our tuning quite well. It is my belief, as well as his, that as long as the block is posted properly by my machine shop, everything should be fine.
Old 11-15-2006, 04:50 PM   #4
HS Troll...And Mod
reikoshea's Avatar
myspace
you should be good, but posting is not a substitute (meaning as good) for sleeving. but it is a cheaper alternative for adding stability to your block.
Anime Informant
Old 11-15-2006, 04:54 PM   #5
D Series FTL
of course it's not a complete substitute. however, 400 hp isn't justifyable for sleeving to me.
Old 11-15-2006, 05:21 PM   #6
HS Troll...And Mod
reikoshea's Avatar
myspace
nor me, which is why i tend to agree with your overall solution.
Anime Informant
Old 11-15-2006, 08:01 PM   #7
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
jeff evans and others are making 450-500+ on stock sleeves, without posting. tuning, tuning tuning.
handlebarsfsr is offline   Reply With Quote
Old 11-16-2006, 03:33 AM   #8
D Series FTL
interesting. i'll probably just have it posted anyways, more of a mental security thing.
thanks for the help everyone
any other suggestions to throw my way?
Old 11-16-2006, 01:43 PM   #9
HS Troll...And Mod
reikoshea's Avatar
myspace
only thing really is the gt35r might be a little big for your goals, but ive never gone that high on a b18b. an lsvtec (gsr head) would definitely hit 450+ at 20 psi. I dont know if a stock ls head flows well enough to do the same.
Anime Informant
Old 11-16-2006, 02:21 PM   #10
D Series FTL
I was thinking about that this morning. Considering costs, I will probably just do a T3/T04E 60/63 .50 trim. I can get them brand new for about $600. The LS head will also be ported and polished as well as turbo spec crower cams, full valvetrain.
Old 11-16-2006, 02:29 PM   #11
HS Troll...And Mod
reikoshea's Avatar
myspace
i think your second choice is much more in the range of a budget build and it will meet your power goals as well. i say go for it.
Anime Informant
Old 11-16-2006, 04:27 PM   #12
D Series FTL
Indeed I shall. I'm wondering if I should spend the money on a nice equal length / ramhorn manifold or whether I should just go log. Eh fuck it. I like purdy manifolds that flow better. I'll do equal length.
Old 11-16-2006, 06:23 PM   #13
Rep Power: 14 divisii is off the scale
Only thing I'd say, make sure you have the ignition/fuel output to handle this .. oh, it deserve a nice header too.
Posting has been successfully used for years .. nice list.
1999 Civic DX--
AEM CAI, Magnecor plug wires, 195-50/15x7 alloys
future? B or K swap
divisii is offline   Reply With Quote
Old 11-17-2006, 12:12 AM   #14
technically a header can be a turbo manifold it just has a point for the blower, right? semantics I guess?
1999 Civic DX--
future? B or K swap
Old 11-17-2006, 05:03 AM   #15
D Series FTL
i know what he meant. cooks turbo headers for mustangs are called just that.
its basically a tubular turbo manifold rather than conventional log style. and yes i do intend on using a "turbo header"
Old 11-17-2006, 06:12 PM   #16
Nah, Blanco, you're all good ... I agree terminology does matter. Normally,
I type the shortest possible answer ... which can come out confusing for some.
Turbo may come from the term turbine, but they are definitely not the same! A blower is a belt-driven device for 'stacking' air into an intake manifold using a screw-type or other style rotor, & was originally intended for large diesel/farm equipment motors/engines. (term- engine or motor??) A centrifugal supercharger is a belt-driven turbo ....... on & on.
1999 Civic DX--
future? B or K swap
Old 11-18-2006, 08:32 AM   #17
D Series FTL
guys it's okay. i know terminology, and i know the contexts used in this thread.
lol this is going to get expensive real quick
Old 12-13-2006, 10:05 PM   #18
Rep Power: 6 4x4crx is on a distinguished road
just fired my built turbo b16 up last night. waiting for tuning built just haw u said ur goin to build yours. your be fine. 400 easy hp.(lots of dyno time)and even more money
4x4crx is offline   Reply With Quote
Old 12-14-2006, 04:27 AM   #19
D Series FTL
dyno time and tuning is no big deal.
me and my roommate have tuned many, many turbo setups. uberdata, chrome, hondata, megasquirt, you name it.
oh, and i decided to go LS-VTEC. no sense not to realistically.
1999 Accord EX - The Baller Ride / Beater
Project Turbosaurus Rex in the works.
www.skandalousinc.com for bags, body drops, boobs, and beer.
Old 12-14-2006, 02:02 PM   #20
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
good job
http://pandora.com/
Old 12-14-2006, 02:16 PM   #21
D Series FTL
plus, i want to have vtec in both my cars. the beater, and the nice car. and by nice car, i mean my accord. F23 a woot.
Old 12-14-2006, 11:51 PM   #22
Ride:  '91 Civic hatch DX
Rep Power: 9 Exodus is off the scale
Send a message via ICQ to Exodus Send a message via AIM to Exodus Send a message via MSN to Exodus Send a message via Yahoo to Exodus
I assume you are using ENDYN posts, why not get their block girdle as well? These two things should provide adequate bottom-end strength considering the potential revs that engine will see, as well as the amount of boost you're throwing at it. Performance per dollar gives a thumbs up to those two compared to sleeves, IMO.
BTW, the correct term is ENGINE, a motor is ELECTRICALLY powered, engine's power our cars
MSD is the ONLY choice for ignition upgrades, which you may need for your setup. The only other thing I can recommend would be coil-on-plug (not coil-packs, that's different than coil-on-plug), which would then give you infinite spark potential. I've not got much to say beyond that except that it would behoove you to check with a Honda Bike dealership and price out the cost of the main pieces there Beyond that, research is your friend.
Don't forget, you'll need a MAP sensor capable of handling this engine, look for the Motorola 2.5 bar, GM 3 bar bows to it.
A word of advice, I'd put more focus into your fuel\oil\spark than the long-block. All of us can list of how we'd like to build ours with an unlimited budget, and they would all handle a lot of abuse, but most forget that these dream-engines still need excellence in oil\fuel\spark delivery to work\last\make power.
glhf!
Exodus is offline   Reply With Quote
Old 12-14-2006, 11:53 PM   #23
Rep Power: 0 importmac69 is on a distinguished road
This May Sound Stupid But How Do I Start A New Thread Im New To This
importmac69 is offline   Reply With Quote
Old 12-15-2006, 12:04 AM   #24
HS Troll...And Mod
reikoshea's Avatar
myspace
go to the forum for your question (if you wanna put an engine into your teg, your gonna be looking to go to the integra section or the Hybrid -> DC section).
Once there click the New Thread button towards the top.
Anime Informant
Old 12-15-2006, 12:12 AM   #25
Were Is The Forum
b18b ls/vtec build Christiphera Engine Building 3 09-14-2006 09:34 PM
General b18b build with turbo question. a_integra_87 Engine Building 1 10-29-2005 04:53 PM
B18B build up Blanco Engine Building 60 06-25-2004 09:39 PM
B18b N/a Build In A 92-95 Civic Ex Coupe thepester Engine Building 3 03-15-2003 02:57 AM
b18b build up inspecta83 Engine Building 44 10-29-2002 03:41 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
