400 hp b18b build
Old 12-17-2006, 06:51 AM   #26
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
Look at the header in the top of this page.
It says " Hondaswap > Honda Tech :: General Honda Performance > Engine Building "
Those are the Forum > Subforums.... Go into one of them, and in the top left, you will see a "start new thread" button.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 09-27-2007, 03:36 AM   #27
Rep Power: 0 bsixteened91 is on a distinguished road
i havnt heard of posting a block before. could someone explain that to me quick like? i've heard of sleaving but not posting
bsixteened91 is offline   Reply With Quote
Old 10-14-2007, 02:54 AM   #28
Rep Power: 5 stock'sLS/VTEC is on a distinguished road
It will not be easy but it definitely possible.... I am hoping to get into the 300hp club. I am doing an LS/VTEC setup with every possible thing done... I would suggest that you go with OBX cams, they are the biggest/best cams for integra/hondas... look at the lift and duration specs... Stage 3... I have some for sale if you are interested... brand new!O I changed my mind 400hp should not be too hard if you do it right... especially pushing 18-20 psi
stock'sLS/VTEC is offline   Reply With Quote
Old 10-19-2007, 10:03 AM   #29
Rep Power: 10 danse will become famous soon enough
Looks like you have a great plan going, I don't know if you need to do the valve train though if you are running a turbo,. The stress on the engine goes up at the square of the RPM, you don't need to spin it higher just run a bit more boost. Posting the block is a solid way for added stability while you are there he also has great diy guides for porting your heads which I did. From dyno work that has been done I am running GSR cams in the turbo engine and you can find a set real cheap, from all the people who have to have obx or skunk cams out there. When I built my current engine I port matched everything and or ported every part of the engine as I put it together, by doing all the little things it adds up in the long run to a much stronger engine. And if you are in an area with E85 I would convert to it, you got to love 105 octane pump gas.
danse is offline   Reply With Quote
Old 10-19-2007, 12:22 PM   #30
Rep Power: 5 WRSXman is on a distinguished road
couple questions, what does posting your block mean, and the other thing that guy was talking about the grill or something? Also does sleeving refer to your piston sleeves? sorry for the dumb questions, im rebuilding a B18C and im just trying to learn as much as i can...thanks!
WRSXman is offline   Reply With Quote
Old 10-19-2007, 09:58 PM   #31
Posting is adding "posts" they are screws that are made out of the same material as the block and screwed into the block and help hold the liner in place limiting distortion as the engine runs. Sleeving is the liner that the pistons run in, as in resleeving....
Old 10-21-2007, 11:03 PM   #32
gotcha...anyone know where i can find a website that shows me how to tear down and rebuilt a B18C1?
b18b ls/vtec build Christiphera Engine Building 3 09-14-2006 09:34 PM
General b18b build with turbo question. a_integra_87 Engine Building 1 10-29-2005 04:53 PM
B18B build up Blanco Engine Building 60 06-25-2004 09:39 PM
B18b N/a Build In A 92-95 Civic Ex Coupe thepester Engine Building 3 03-15-2003 02:57 AM
b18b build up inspecta83 Engine Building 44 10-29-2002 03:41 PM
