aluminum crank pully cause oil pump failure?
Old 07-03-2009, 12:28 AM   #1
Rep Power: 5 blasterman87 is on a distinguished road
Default aluminum crank pully cause oil pump failure?
my b16a1 came with a aluminum underdrive pully, and ive been told that sence it doesnt have rubber in it like the factory one it wont obsorb shock, this transfering the shock to the oil pump eventually shattering it. is there truth in this?? i looked up the pully and its listed for the b16a2 and not the b16a1, and the newer a2 has a counterbalanced crank unlike the older a1.
blasterman87 is offline   Reply With Quote
Old 07-03-2009, 12:53 AM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Crankshaft balance does not have much to do with harmonic vibrations caused by the individual strokes themselves(the vibration comes from crank flexing).
With a B16, since it has a really short stroke, I don't think it'll really be a problem. But, there's always that risk so if you just want to be sure, run a dampened pulley.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 07-03-2009, 09:07 AM   #3
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
The general concensus is "dont use it". Some people have reported failures, others say its just fine.. But why run the risk? The engine was engineered with a damper, you should use the damper. They didn't put it on there for kicks.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 07-03-2009, 10:58 PM   #4
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
people do a lot of things for dyno-queen engines, and removing the damper is one of them.
Be smart. Build it to make gobs of torque for its entire natural life.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 07-04-2009, 02:54 PM   #5
ok, with that said, whare can i get a pully with dampers in it? does someone make an aluminum one that has dampers? ive put alot of time/money into this swap and i want it to last atleast 100k
Old 07-04-2009, 07:08 PM   #6
Reverend Awptickes
awptickes's Avatar
 FaceBook
Why not buy the CTR crank pulley?
Old 07-09-2009, 05:59 PM   #7
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
the ctr pulley is not a dampner either its a zero ballanced piece that has no dampening ability
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Crank pully Tein Civic and del Sol - EG and EK 4 02-10-2008 02:51 AM
N1 Crank Pully Quiklilefr Engine Building 10 06-09-2005 10:55 PM
crank pully not ballanced... CRseX84 General Tech and Maintenance 1 06-26-2004 05:54 PM
wanted DA crank pully b18burna Parts: For Sale/Trade/Wanted 2 11-24-2003 07:12 PM
help with my crank pully serialkilla187 HYBRID -> ED-EF / DA 3 09-10-2003 12:14 PM
