anothr rwd v8 civic.
Old 05-26-2009, 01:52 PM   #126
Crazy Insane
disableddan's Avatar
Ride:  1990 HB (K.I.A.), 2001 Coupe
Rep Power: 21 disableddan is a splendid one to beholddisableddan is a splendid one to beholddisableddan is a splendid one to beholddisableddan is a splendid one to beholddisableddan is a splendid one to beholddisableddan is a splendid one to behold
^^ Preludes were designed looking like a rwd. It's unfortunate they aren't!! There would be a lot more of them on the road I'm sure...
I was checking out the underside of my 01, its like they want it to be rwd'd... massive tunnel for the exhaust and shift linkages (like way too big for said parts to ever fill it), and the bottom of the trunk looks like it can be removed as one big "box", which would completely open up the rear-bottom of the car....
Long live the rwd-v8 conversion.
disableddan is offline   Reply With Quote
Old 05-27-2009, 02:37 PM   #127
Ride:  92 f150 4X4 and 96 honda civic
Rep Power: 16 lildj2483 is a splendid one to beholdlildj2483 is a splendid one to beholdlildj2483 is a splendid one to beholdlildj2483 is a splendid one to beholdlildj2483 is a splendid one to behold
here is a few recent pics with the 4.6 in it. im going to start on the box frame pretty soon. and will make the motor mounts and rack and pinion bolt off of that. this 4.6 fits so much better then the 5.0 does. well enjoy the pix will have more updates later. oh and with the t45 transmission behind it. i will have to customize a driveshaft this time. but i think i can handle it.
lildj2483 is offline   Reply With Quote
Old 05-27-2009, 04:05 PM   #128
Rep Power: 6 khrys771 is on a distinguished road
looks alot wider then the 302!
khrys771 is offline   Reply With Quote
Old 05-27-2009, 04:13 PM   #129
it is but it seems to be alot sshorter and shorter from front to back. it fits so much better.
Old 05-27-2009, 04:27 PM   #130
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
That hood looks badass, like the motor's just busting it's way out. You should leave it exactly like that, such a sweet rat rod.
klyph is offline   Reply With Quote
Old 05-27-2009, 04:31 PM   #131
for the correct gt harness its going to cost me between 3 and 8 hundred dollars
this engine has 412 and almost 450 ft lbs of tourqe i was told by the builder. cant reember the exact torque.
Old 05-27-2009, 04:34 PM   #132
Dismember
800 bucks, shit you could buy a standalone management system for that kinda coin. You sure you can't find one in a junkyard, or is 300 bucks the junkyard price?
Old 05-27-2009, 04:35 PM   #133
but it has to be for a 96-98 mustang gt with the T45 transmission and the 4.6. i called every single junkyard within 50 miles and cant find squat
Old 05-27-2009, 04:41 PM   #134
i mean i have a wiring harness to run the motor but its not the gt harness. it wont perform like its suppsed to. my friend would hit speeds of 160 no problem. with his 03 cobra motor he currently has 700 hp and can hit 170 in 5th gear and still has 1more gear left.
Old 05-27-2009, 04:47 PM   #135
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
Yes i would look into an aftermarket sms.
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 05-27-2009, 04:51 PM   #136
well 300 bucks is several peices that i need off of ebay.
Old 05-27-2009, 06:31 PM   #137
ŋGANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
you cant do a custom harness???
this thing is badass..you should do a cowl hood..im soo pumped to see it run..
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 05-27-2009, 06:36 PM   #138
no i cant do a custom harness it has that pats setup on it. that anti theft garbage. i can get it turned off for 400 dollars when they reprogram the ecu though. but fk that. im working on the frame setup rightnow. running from the front to the back bracing up the car. designing my own tube frame because i know this thing will deff twist the car. going to call tomorrow and see how much some 2 inch tubing at a local steel place. oh and i plan on putting a cowl on it. that would look sweet..... this hood is garbage anywas thats y i cut it up like that haha.
Old 05-27-2009, 06:41 PM   #139
ŋGANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ohok..well goodluck on the whole harness thing..keep up the goodwork and keep going with updates
GOOD FAST CHEAP,
Old 05-27-2009, 06:43 PM   #140
i just found a wrecked 97 gt almost like my friends that i got this motor from. well he only wants 50 bucks for the dash harness. imma go check it out this weekend and see what else i can get off this car if not the whole body haha.
Old 05-27-2009, 10:37 PM   #141
i wonder how this would look on the hood. ofcourse i would have to cut it to make it be only like 27 to 29 inches long. lol
Summit SUM-470451 - SummitŪ Hood Scoops
Old 05-27-2009, 11:34 PM   #142
Token GM Guy
double0Si's Avatar
Ride:  91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
Rep Power: 119 double0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
double0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond reputedouble0Si has a reputation beyond repute
myspace
You should try THIS one instead. And its only 27" long, a little pricey though. Or this SLP one at 25".
double0Si is offline   Reply With Quote
Old 05-27-2009, 11:36 PM   #143
wrong width though. needs to be 28inches wide.
Old 05-27-2009, 11:40 PM   #144
Token GM Guy
double0Si's Avatar
myspace
well shit...
Si vis pacem, para bellum
There are no stupid questions, but there are a lot of inquisitive idiots.
TWIN Turbo V8 CRX
Originally Posted by 93civicracer View Post
I'm a real enthusiast for Japanese cars, I like the small things here n there that are different on jdm vehicles like lips, foglights, and the tiny differences especially the emblems for some reason.
Old 05-27-2009, 11:49 PM   #145
because i want to make sure everything is going to fit plus its not that expensive although i might just make a mold and then lay some fiberglass. then glass it onto another hood,haha. tomorrow im going to see how much some 2 inch and 2x3 inch tubing is. im going to put a motor in my truck and sell my truck. so i can buy everything needed and do it right. my civic looks funny. i have a garbage bag ducktaped over the hole in the hood. haha. the guy that built this motor passed over today and said damn that thing almost looks natural in there.
here is a corection to what i said......"he came by" the builder of this engine did not die.
Old 05-28-2009, 12:20 AM   #146
Old 05-28-2009, 01:01 AM   #147
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 21 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
You should put a blower on that thing. Civic with a blower.
For ref here's a 302 with a blower ;x. Yep..... Blower.
Edit: sorry to hear about the builder.
PSN: Korax37
Korax is offline   Reply With Quote
Old 05-28-2009, 03:10 AM   #148
Dismember
LOL! He wouldn't have said anything if he was dead!
Poorly worded sentences FTW!
I'm pretty sure he meant "passed by"
Old 05-28-2009, 05:53 AM   #149
yes it was just a poor choice of words. i was kinda half asleep and wasnt thinking fully. i apologize, i edited and put below it what i meant so people will understand what i mean.
thanks kylph for helping
Old 05-28-2009, 11:17 AM   #150
im being smart this time
this time i took some measurements and got it planned out
this is pretty much what im going to build inside the car frame wise. and im going to get my friend to builda roll cage going from in the trunk all the way to the very front.
since im putting this 412 hp engine in the car im going to do everything right from here on out.
