#202 | |
!!YTINASNI
Why the scrapping deadline?
#204 |
Token GM Guy
Ride: 91 Camaro/07 GSX-R600/2000 Civic Si JDM B16A Hytech replica header Password JDM intake S2 camber kit
Don't scrap it! ^He^ sounds serious!
Si vis pacem, para bellum There are no stupid questions, but there are a lot of inquisitive idiots. TWIN Turbo V8 CRX |
#205 |
Ride: 92 f150 4X4 and 96 honda civic
lol. because i know it should be done by then. well the front subframe out of a 83 mustang fit beautiful. just need to make a spacer in the back and a bracket for the first bolt but the middle bolt all i have to do is drill a hole through the frame and then put a long bolt through. but all in all it fit really great. i will have pics up as soon as i can take them. and like i said im going to just get it running with a 302 and might upgrade it later. im going to get everything needed to make it carburated for now and might go to 4.6 later or just will put the 4.6 into someting else. i have had a long day taking everything out of that mustang to put it into my civic
#206 | |
!!YTINASNI
Was hoping for the carbureted engine anyway. Keep up the good work! __________________
#207 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
do not scrap it or i will talk to B about banning you...
u better follow through with this ENTIRE build.. __________________
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#209 |
well had to faness the back upper bolt hold on the driver side of the crossmember too work a little better. but the back upper bolts will actually bolt up to the OEM crossmember bolt holes . im going to make up a bracket for the front and not sure what im going to do with the very rear bolts. but so far looks like evrything will work out justfine. i will try to have pics of it later today. i still havent been able get my hands on a digital camera so i will still be using a camera phone. and the mustang cross member will leave it sit low and looks like it will be just a little further back then i had it so im not sure how the driveshaft will fit just yet. i will keep updating though. well if i can have the car done and waiting for the motor by friday then everything will be ok. but if i still have to much work then i dont know what to do. i cant keep spendng all this time on this car. i also need to work on my truck. i have to get the windshield for my truck. i wanna go playing in the mud again haha. i was actually thinking of putting the mustang body ontop my truck frame lol. that would look kewl i think,lol
#213 |
well the mustang subframe is bolted to the car i still need to make the brackets for the front bolts and make it where the shocks will bolt up also. im working on doing that and also put in the coil springs right now.
#217 |
no i had the subframe sitting on blocks still
it sits beautiful well i just put some wheels on it and i a working on fabin up the shock towers to be able to hold the shocks. then i am going to cut the springs and put them in. and it all lines up beautiful. |
#218 |
but when i get the springs in and sitting on its own. with no blocks or chains holding it up i will ake a pic from underneath but as of right now i can make it sit anywheres i want really,lol
#220 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
have you done any measurements for the driveshaft???
#221 |
so far the shaft works perfect he told me.
the driveshaft is out of a mustang lildj2483 : the yoke is from the mustang also lildj2483 : the transmission im using is out of a ford e150 van and the rear yoke. the one that bolts to the rearend is the only other part off the mazda besides the rearend Last edited by khrys771; 06-02-2009 at 06:00 PM. |
#222 |
its an oem driveshaft for the 83 mustang. but the flange on the back is off the mazda b4000 the reason i changed the flange is because the mustang flange is to small because the mustang rearend is the 7.5 and my rearend is a 8.8
#223 |
ok well heres an update. the whole subframe needs to be moved back around 2 inchs. i dont know if we just measured wrong or if it was due to the fact that this car was wrecked in the front. even the oem front end was out of whack. so im just going to unbolt it and then just move it back some and then just drill a hole in the frame and put a long bolt. i will update more later
#225 |
all i have left to do with the front crossmember is make the brackes for the front 2 bolts. i made the rear top bolts work. i drilled clear through the frame and put some 1/2X7 bolts through the frame. and as for the 3rd pic i just thought that was funny.
