Arp Head Studs
Old 06-12-2003, 01:26 AM   #1
Rep Power: 17 noobvang is off the scale
Putting ls/vtec together with ARP head studs. Went looking in there site for some specs but came up nothing. Would like to know how much should I tourqe the head studs. Should I go factory spec? (63 ft/lbs.)
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC.
Best run on 1320:
14.5 @ 94.5mph street tires
14.4 @ 94mph small slicks :P
98 Yamaha R1
noobvang is offline   Reply With Quote
Old 06-12-2003, 01:25 PM   #2
Rep Power: 29 knowledge is off the scale
Yes torque them to factory specs.
The C5 is strong with this one........
knowledge is offline   Reply With Quote
Old 06-12-2003, 10:12 PM   #3
Rep Power: 0 Ryan C is off the scale
i ran into the same problem...i called arp they said it was up to the mechanic...all they said was make sure you do it in at least 2 stages... so i did factory shit and it worked fine. make sure you use the moly lube
...Ryan C...
Ryan C is offline   Reply With Quote
Old 06-12-2003, 11:56 PM   #4
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
NO NO NO!!!
using arp moly lube torque them to 72 ft lbs
or using 30wt motor oil it's like 83 or so ft lbs.
but make sure it is in 2 stages
pills_PMD is offline   Reply With Quote
Old 06-13-2003, 01:53 AM   #5
Got It!
Thanks folks!
Best run on 1320:
98 Yamaha R1
arp head studs for gsr block w/ b16 head vtecsir1 Engine Building 38 06-17-2006 11:29 PM
NEED NEW B18C1 ARP HEAD STUDS arpee79 Parts: For Sale/Trade/Wanted 1 01-29-2004 10:57 PM
B18A1 Can I add VTEC? psychochicken HYBRID -> ED-EF / DA 9 01-19-2004 10:31 PM
I think I found it! B-18Hatch Members' Lounge 8 08-08-2003 12:12 AM
