Auto To Manual Swap
Old 03-05-2003, 10:41 AM   #1
Rep Power: 0 civicdude98 is off the scale
i am thinkin about swaping a D16Y8 motor with a manual tranny into a D16Y7 auto car what all do I need to have to accomplish this?
civicdude98 is offline   Reply With Quote
Old 03-05-2003, 11:02 AM   #2
Rep Power: 18 jeffsciv23 is on a distinguished road
Send a message via AIM to jeffsciv23
you will need tranny, flywheel, clutch, slave cylinder, master cylinder, pedals, new ecu (i think you might be able to use you old one if you cut some wires), and the fluid lines and misc bolts. anybody help me out if i missed anything.
jeffsciv23 is offline   Reply With Quote
Old 03-05-2003, 04:38 PM   #3
Rep Power: 16 aznhottiekj is off the scale
what is a slave cylinder and master cylinder??
aznhottiekj is offline   Reply With Quote
Old 03-05-2003, 04:43 PM   #4
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
The clutch master cylinder is where the clutch fluid is contained (in a hydraulic clutch setup) and distributed from, and the slave cylinder is at the end of the high-pressure high and is what actuates the throwout bearing inside the tranny. They don't exist in a cable clutch setup.
Someone please elaborate or correct me if I'm wrong.
This space left intentionally blank.
Old 03-06-2003, 01:51 PM   #5
nope, that sounds about right to me.
Auto VS Manual ECU reckedracing ECU's, Electronics, and Tuning 6 06-14-2004 06:48 PM
auto to manual swap wiring??? thegreat1310 HYBRID -> ED-EF / DA 2 01-19-2004 06:29 PM
Auto To Manual dustylax ECU's, Electronics, and Tuning 1 05-14-2003 02:00 PM
Auto To Manual dustylax HYBRID -> EG-EK / DC 0 05-14-2003 01:20 PM
