B IM to D head??
Old 10-21-2003, 08:08 PM   #1
Rep Power: 20 SolLess16 is off the scale
Send a message via AIM to SolLess16
hey guys wondering if you can make a bseries intake manifold fit a d series head - i heard all you have to do it is drill alittle bit but want to know - i tried searching but came up empty - also will fuel rail and injectors fit and everything else work - thanks
93 Del Sol - D16Z6 Turbo
SolLess16 is offline   Reply With Quote
Old 10-21-2003, 08:17 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
No. You can move the injectors around if you stay within the same OBD revision, but the IM will not work. It's a different size... port spacing is most likely different.
Old 10-22-2003, 02:54 AM   #3
Rep Power: 17 noobvang is off the scale
What Calesta said, and port spacing IS different.
Your answer: no.
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC.
Best run on 1320:
14.5 @ 94.5mph street tires
14.4 @ 94mph small slicks :P
98 Yamaha R1
noobvang is offline   Reply With Quote
Old 10-22-2003, 03:01 AM   #4
Retired OG
Ride:  Integra, Tahoe
Rep Power: 43 kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
Kyle I. Collins, PmD.
kyleirwin is offline   Reply With Quote
Head Gasket Repair (o)(o) General Tech and Maintenance 24 10-02-2007 12:09 AM
B18A1 Can I add VTEC? psychochicken HYBRID -> ED-EF / DA 9 01-19-2004 10:31 PM
I think I found it! B-18Hatch Members' Lounge 8 08-08-2003 12:12 AM
Want A High Revving Monster? maverick97 Engine Building 10 06-26-2003 04:25 PM
