B16 Block Ls Head, What Should I Exect?
Old 01-14-2003, 08:19 PM   #1
Rep Power: 0 kanscrx is off the scale
First off, Hi all, My names Alex, I'm in Kansas, and I'm new to the board. I currently drive an 88 CRX w/a D16Z6 in it.
Well, after one friend doing a CRVTEC (b16 head), and one doing LS/VTEC, i now have a free LS head, and a $100 stock, good, b16 block. I was wondering, if I put the LS head on the B16 block, what kind of hp/tq #'s would I see? Could anyone give an accurate guess on Compression ratio? After talking with some friends, we thought that since the b16 block is good for upto 9000 rpm, we could put some cams/springs in the LS head, so it'll go to 9000, then we would have a nice little screamin' turbo engine. Or would the c/r be higher than 9.5:1? Anyone have any thoughts? Either that, or maybe it would make a nice high revving NA engine? I Guess the only way to find out is to build it, and put it in my rex.
All input appreciated,
Alex
kanscrx is offline   Reply With Quote
Old 01-14-2003, 08:43 PM   #2
Rep Power: 30 SolReaver is off the scale
sup alex, welcome to HS
I dont have much experience with ls/vtec or vice versa, but what youre doing sounds interesting
I would get the crower ls turbo cams, dual valve springs, and a nice big turbo.
No idea on the power numbers, but i bet it would be a nice powerful motor
Good luck, and let us know how it goes!
<a href=\'http://www.FreeiPodShuffle.com/default.aspx?r=15723497\' target=\'_blank\'>Get a free ipod shuffle, Yes it works! </a>
I will paypal $8 to the first 3 people to complete the offer, PM me if interested.
SolReaver is offline   Reply With Quote
Old 01-14-2003, 09:22 PM   #3
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
I thought about building that as well because I have a B16 bottome end and I had an LS head after doing my LSVTEC, but I have heard (I can't confirm or deny it) that that engine has a lot of oil leaks. That could be BS, but I am not sure. I decided against it in the long run due to cost. I don't know what timing belt you would use. You would have to plug the VTEC oil passage in the block. Those are the only issues that I know for a fact you would have.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 01-14-2003, 11:00 PM   #4
Yeah, i had already figured on blocking up the passage, (opposite of an LS/VTEC), which isn't a problem at all. It seems like the b16 timing belt will fit too. So far, the only issue i see is the oil passage, so it shouldn't be that hard. If we had a dyno around here, I'd do it soon and post some numbers..alas, no such luck!
Alex
Old 01-14-2003, 11:05 PM   #5
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
this does sound like an interesting little project... i'd really like to see a dyno sheet when youre done. just how lsvtec and crvtec came about, who knows maybe everyone will want a lsb16 now!!! hurry, get a patent on it
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 01-14-2003, 11:06 PM   #6
Rep Power: 25 SixtySecondAssassin is off the scale
sounds cool. its like a beefed up zc.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 01-16-2003, 12:08 AM   #7
Rep Power: 0 speed- is off the scale
Hmm does sound interesting.
99 Teg LS i/h/e and some other goodies
speed- is offline   Reply With Quote
Old 01-16-2003, 12:15 AM   #8
Rep Power: 26 2 litre EG is off the scale
Send a message via AIM to 2 litre EG
that is an idea, i wouldn't do it cause of cost like lsvtec said... i dont have the time, patience or MONEY above all to do a project of that sort... but go for it and let us know how it went
PS: welcome to the board
Jason -
2.0L ls/vtec - 13.23@107 on slicks
<a href=\'http://www.hondashowoff.com/profile.php?id=3042\' target=\'_blank\'>My Honda Showoff Gallery</a> - Vote for Me!!!
<a href=\'http://www.hondaswap.com/gallery/browse.php?album_id=178\' target=\'_blank\'>My Gallery on HondaSwap</a>
<a href=\'http://www.hondaswap.com/gallery/album.php?mode=view&album_id=311\' target=\'_blank\'>My Other Album</a>
2 litre EG is offline   Reply With Quote
Old 01-17-2003, 08:17 PM   #9
Rep Power: 0 sensation is off the scale
I don't think it's possible or even worth it. Save money for complete motor. But if you want to experiment, you'll gonna need to get a tranny if you don't have one. But remember that high revving non-vtec motors lack low-end power.
sensation is offline   Reply With Quote
Old 01-18-2003, 04:39 AM   #10
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
It's definitely possible- if you can bolt a B16 head onto a B18 block, you can do the same in reverse... it's just that nobody would want to do that for the purpose of a power increase.
Also, a high revving VTEC engine will have the same piss-poor low end as the same engine setup with VTEC- you don't use the VTEC lobes at low revs anyway.
LS VTEC for sale - B16 head b18 block Anthrax-VX Parts: For Sale/Trade/Wanted 8 04-08-2009 12:29 PM
B16 block and GSR head Dra6on45 Engine Building 31 03-05-2008 11:24 PM
H23 block and H22 head for sale! Doomster9 Parts: For Sale/Trade/Wanted 3 09-10-2006 01:40 PM
I think I found it! B-18Hatch Members' Lounge 8 08-08-2003 12:12 AM
