Banned
Wasup, I was wondering what to do to make more power out of my B16. I might build an ls/vtech or b20
I dont know what to do or should i keep my 16 and raise the compression cause its a 1.6. What about cams i heard only 16 whp. What should I do for I/H/E (intake,header,exhuast) and if I build a b20 will my axel be ok THANKS, Zoarette racing team |
#2 | |
Member of the 20 nut club
LS/VTECH ????
you mean this??? ![]() __________________
МОΛΏΝ ΛΑΒΈ |
Woo Woo!
![]() VTEC!, genius! __________________
My skin is singed but it heals my heart and with glowing pride I'll wear my scars. I'm honored by your hatred! She wanted love, I taste of blood. She bit my lip and drank my warmth from years before. |
First thing you can do is to spell better
1990 CRX DX in the works, ls swap now running IN CAR! RDM ownz JOOOO!!!!!!!!! |
#5 |
#6 | |
Admin with a big stick
Ride: 2003 S2000
#8 | |
I can't believe I had to fucking explain that shit. I feel fucking dumber now! __________________
For all your air suspension needs <a href=\'http://www.ultimatesporttruck.com\' target=\'_blank\'>Three Rivers Ultimate Sport Truck</a> **There are many misconceptions of air ride and handling. A lot of bullshit spread, please PM if you wish to put air on your car/truck. You will get the 411. There ARE ppl who race with air ride, just have to know how to install it right.** |
#11 |
I have never laughed out loud so hard reading responses
that graph is pure gold. Vtech__________________
"Our enemies are innovative and resourceful, and so are we. They never stop thinking about new ways to harm our country and our people, and neither do we." -The thought provoking George W. Bush |
#12 |
By the way, does zorette racing have any open spots? I mean, I don't have VTECH or a 2.0L b16, but hey, I will try to keep up with you guys at the track.
#15 |
Btw, it's probally impossible to get a B16 to 2.0 lt.....Since EVEN if you sleeve the block, the biggest bore you can get out of it is 84 mm or you'll start thinning out the water passages thus cracking the cylinder walls in the long run....Besides that, the only other thing you can do to increase the displacement would be to increase the stroke, since the deck height of the B16 and B17 are alike, you can swap a B17 crank into the B16 motor and use B17 rods to increase your stroke without running into piston to valve problems....I did the same setup in my ride....I had to do all the research so I talked to AEBS professionals and to some of the local shops who do this kind of stuff every day, and most come up with 100 different viewpoints....But I say upgrading your B16 will be worth it.....Mostly because the R/S will be better than any other block you work on guarenteed.
#16 |
Banned
If I Do swap the B17 crank into my 16, Wont I have to much low end power cause Im still running stock clutch ,and stock axles. Every thing would snap It sounds good though how much HP are you pumpin what about a lighter fly wheel I heard that if you go to light you loose revs when shifting, is it really worth buying a new one or a used
Thanks Zoarette racing |
#17 |
the power gained with that crank isnt going to break things. it only adds about a tenth of a liter of displacement. the power gained depends on what rod/piston combo you use. i dont know if you can use the b16 rods, they might be too long.
.....deagle..... |
#19 |
yes the type r maifold will bolt up. i think the skunk2 and the type r are pretty similar. the others you mentioned are pretty extreme and i dont personally know how they perform or if the are suitable for street.
.....deagle..... |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| B16 Build Up Questions | allmotord16rex | Engine Building | 3 | 07-21-2003 09:42 PM |
| B16 Turbo Build | DarKatana | Engine Building | 4 | 07-02-2003 03:39 PM |
| B16 Or B18 Build Stories | XZILER8 | Engine Building | 6 | 04-30-2003 02:31 PM |
| b16 Build Up or $Free$ LS block? | b16vtec93 | Engine Building | 3 | 10-02-2002 07:53 PM |
