B16 Build Up Questions
Old 07-21-2003, 07:14 PM   #1
Ride:  Honda S2000
Rep Power: 19 allmotord16rex will become famous soon enoughallmotord16rex will become famous soon enough
Hey, I need some help building a B16. I have been trying to figure out different combinations for all motor power. Does anyone know which B series crankshafts with rods are compatible. I have heard the b17 rods and crank will fit, but do they need modification? What about the B18b or C cranks and rods? Thanks.
2002 Honda S2000
Bone Stock
***Sold****
90 CRX SI
JDM DOHC ZC
Jackson Racing Supercharger
165 whp @ 7500 rpm
allmotord16rex is offline   Reply With Quote
Old 07-21-2003, 07:20 PM   #2
Well you can use any B series pistons except for the B20's in order to raise compression and make that bore a littler larger by .25mm. I posted a cam guide up top so you can check out which one would fit into your budget and goal the best. P&P I would go with alaniz/portflow/dpr. Bottom end work I would trust RS machines, Ericks, IB, GE. The key with the b16 is to have a light car, and make sure to get the proper gearing that came with that motor. As far as bolt on's I would recommend Comptech Icebox, either SMSP or Hytech headers, straight through 2.5" exhaust mandrel bent piping with a nice muff. Light flywheel such as toda, jun, fidanza, spoon and a decent clutch. Port match your Tb wtih your intake manny and head for smooth flow. 12:1 compression is usually max for street use but you can go higher wtih tuning from hondata. Little wide tires that are sticky and your good to go. have fun.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 07-21-2003, 08:18 PM   #3
B16
B16's Avatar
to answer your question about stroking, yes B17 crank and rods, but not B18 stuff.
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 07-21-2003, 09:42 PM   #4
oppsss.....my bad, guess I got carried away.
Milan
TONS of parts for sale B16, GSR, Type R Envy_Motorsports Parts: For Sale/Trade/Wanted 25 10-16-2008 01:08 AM
B16 Swap General Questions fardoche HYBRID -> ED-EF / DA 9 03-01-2004 01:09 PM
swap questions B16 into eg sleepercivic HYBRID -> EG-EK / DC 4 07-02-2003 01:32 PM
B16 Build ?s heterosapian Engine Building 2 03-10-2003 07:05 PM
B16 Build Up Zoarette-racing Engine Building 18 02-20-2003 09:07 PM
