b16 head, gsr block
Old 01-26-2006, 08:04 PM   #1
CrazyAzn's Avatar
Rep Power: 17 CrazyAzn is off the scale
okay well i noe this is called a poormans itr, but i was wondering what head bolts could i use? would i use b16 head bolts or gsr bolts?
or rather can i use b16 head bolts?
or do i have to use gsr bolts?
im asking this because ir ead something on imporbuilder that people strip the head bolt holes, due to shorter headbolts. . . im not sure about this, which is why im asking. . .
thanks,
kyle
89 EF build: Poorman's ITR
95 GSR bottom end, .25over b16 pistons Pr3
Zealautowerks compression = 11-8-1
ARP head studs, Stock head gasket
S2 Pro series IM, w/ Hondata intake gasket
Holley 68mm throttle body
ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw)
kteller 2.5 mandrel bend kit.
PnP b16 head w/ dual valve springs and ITR cams
Milled about .030
AEM hybrid CAI
Running obd1 w/ p28 tuned on chrome
Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector.
CrazyAzn is offline   Reply With Quote
Old 01-26-2006, 09:42 PM   #2
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
you use gsr head studs. and its only a "poor mans itr" if you add itr or ctr pistons. switching from a gsr to a b16 head lowers the c/r of the motor by .3, which hurts power. you need to regain that loss with higher c/r pistons or you end up gaining almost nothing.
handlebarsfsr is offline   Reply With Quote
Old 01-26-2006, 11:55 PM   #3
Rep Power: 14 Tyler is an unknown quantity at this point
yep gsr bolts, I have this setup in my hatch, the only thing that the b16 head does better is it flows a little better than the gsr, performance is about the same as a stock gsr
1992 gsr hatch
2004 RM250z all black
Tyler is offline   Reply With Quote
Old 01-27-2006, 01:02 AM   #4
<div class='quotetop'>QUOTE(Tyler @ Jan 26 2006, 11:55 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
uhm... are you trying to stir up a shit storm? this can be argued like a mofo... some say the b16 head flows better than the GSR, some say the GSR head flows better than the B16
90 Integra Sedan
B20V 225 / 153
Old 01-27-2006, 01:06 PM   #5
CrazyAzn's Avatar
thanks guys, i was just wondering which headbolts/studs to use. . .i think ill call up my friend at honda to get me some gsr headbolts. . . lol oh and im running .25 over b16 pistons. . . cus u noe over here in ca, we get shit 91. . haha
thanks guys.
oh and if your wondering the set up is.
95 gsr bottom end, freshly rebuilt/bored/honed/decked
dc headers
2.25 in exhaust
skunk2 IM
aem intake
hondata gasket
holley 68mm throttle body
01 gsr cams
which is going into an ef
Milled about .030
AEM hybrid CAI
