ok i've looked and read and i can't find the same thing anywhere. i want to know what the deal is with the b16 stroke. can it be made to 2.1 like the b18c? i know that they have kits for 1.8 or 1.9? i'm looking for 2.1 lol
thanks for any help |
with allot of $$$ every ting is posible,
and you will need to sleeve this shit too... __________________
I am a simple man with a simple mind</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'></td></tr></table><div class=\'signature\'> |
2265787829
Ride: Refer to my name, dumbass.
You could probably bore it to 2.1, but you'd have to resleeve it pretty thick if you plan on boosting it, which would end up dropping displacement down again.
I know this is a little off subject but ERL makes a pretty bad ass block (1.9) fully assembles for around 3 grand i think. You might wanna check that out.
94 cx hatchback mods exterior- si wheels rapped in falken azenis, carbon fiber hood, carbon fiber wing, projector head lights, si paint job and m3 mirrors under the hood - b16 sir2 swap, clucth masters stage 3 clutch,act lightend flywheel, eagle rods, arias pistons, darton sleeves, rc 370cc injectors, msd plug wires,jackson racing fuel pump, apexi avcr and vafc, thrermal 3 inch turbo exhaust, 3 inch down pipe, auto tecknic fuel rail, b and m fuel pressure regulator,aem cam gears, turbonetics t3/t4e turbo, spearco fron mount intercooler, greedy type s b.o.v, future mods- crane 2 step rev limiter igniton system, pnp head, crower valve train, and a apexi power fc. |
#5 |
boring out a B16.....
I don't see it..... jest get a B18c and play with it if you have money to bore a B16 to 2.1 and you don't neet to bore a B16 to 2.1 to make it fast, = faster than it is, B16 lack of torque, I don't like that.... jest get a B20 block, I will make it easier on you, and on your wallet.... __________________
#6 |
hmm my b16 makes 240ft lbs , but then again im boosted
#7 |
what kind of boost you running, what kar, how much it cost you?
and what's you quarter mile....... ? __________________
#8 |
15 psi, 94 cx hatchback, $ a lot and quarter mile time 12.5
#9 | |
2265787829
Go kill a couple of crappy drivers in a 03 SVTs and 03 Z06s :P |
#10 |
i feel stupid, i just read in your sig that you changed your name. I cant keep up with you guys anymoreAnd thanks for the props,most people dont realize the time effort and money it takes to get to where im at __________________
#11 |
sweet....
#12 |
guys all motor for me. see i can't decide what to do for my setup. the b16 is cheap to get and i've seen them done correctly and can make power. i wanted to stroke or bore b/c of the fact that it lacks torque. either that or get a b16a head and get a itr bottom end and do that but idk b/c idk if it's worth the money. i could build the b16 better for the same price just about. am i right? any thoughts?
thanks for any help again |
#13 | |
2265787829
#15 | |
2265787829
#16 |
i paid 80 per sleeve( Darton sleeves) and 500 to the machine shop to do it, but thats not a enclosed deck
#18 |
Ride: 88 Honda Civic HB
i dont care how much money you have you will never be able to get a b16 to 2.1 with a new bore. you will have to stroke it with the rebore and maybe weld a deck extension plate on. largest bore you can probally run on the b-blocks is about 84.5mm for boosted applications. this will get you to is about 1728cc. in order to get to 2.1L you will need a 95mm crank(2131cc). with the 95mm crank in the b16 you will have a rod ratio of about 1.32(125mm rods)--pretty shitty; thus the need to get the deck plate.
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| Bore and Stroke | Spooner | HYBRID -> ED-EF / DA | 1 | 04-09-2004 11:57 PM |
| bore and stroke for h22 | dragoon118 | Engine Building | 4 | 12-25-2003 09:22 PM |
| WTB: B16 pistons (stock bore) | MaaseyRacer | Parts: For Sale/Trade/Wanted | 1 | 10-04-2003 04:41 PM |
| bore out stock B16 intake manifold? | 12secondCRX | Engine Building | 10 | 07-19-2003 11:50 AM |
