| | LinkBack | Thread Tools |
| | #1 |
| Member | I HAVE A 96 EX, AND A B 16 REDY TO BE SWAPPED THE GUY THAT SOLD ME THE SWAP SAID THAT I WOULD NEED TO UPGRADE MY RADIATOR TO ACCOMIDATE THE B16 SO HE THREW IN THE RADIATOR FROM A GSR, WOULD THIS WORK? WHAT OTHER MODS DO I HAVE TO TO DO TO MY CAR TO PREPARE FOR THE SWAP? ANYONE W/ INFO ABOUT THE RADIATOR SWAP OR RELATED TOPIC FEEDBACK WOULD BE APPRECIATED. |
| | #2 |
| Super Moderator Join Date: Sep 2002 Location: Houghton/Livonia Michigan Age: 23
iTrader: 0 / 0% Ride: 93 del Sol Gas sipper
Rep Power: 102 | first ![]() Don't use caps, its annoying as hell to read. As for the integra raditor, it will work, however, there is a little bit of modification needed, and you can't have AC. If you want AC but better cooling, go with either a Del sol VTEC dual core raditor or an aftermarket raditor. If you don't care about AC, your going to have to fabricate brackets for the top and bottom mounts. |
| | #4 |
| Senior Member | |
| | #6 | |
| Member | Quote:
| | #8 |
| Super Moderator | or get like an autozone replacement radiator... get the 94-96 del sol vtec one, dual core. i'm using an integra radiator in mine right now, but like asmallsol said there is some custom fabbing to be done, namely the upper and lower mounts. |
| | #9 | |
| Member | Quote:
| | #11 | |
| Member | Quote:
| | #13 | |
| Member | Quote:
| | #16 | |
| Member | Quote:
| | #17 |
| Senior Member | Nope, you can't use stock mounts. Go pick up some Hasport mounts for $400. They're well worth it. No there isn't another way arround it. Sorry. This is a list of everything you'll need to do the swap: http://hasport.com/Tech/Installs/Shopping%...20partslist.htm |
| | #18 | |
| Super Moderator | Quote:
[/b][/quote] i always replace radiator hoses if i do a swap. | |
| | #19 | |||
| Member | Quote:
[/b][/quote] do the axles need to be upgraded also? | |||
