B16 Swap Into 1990 Teg
Old 05-12-2003, 08:37 PM   #1
Rep Power: 0 90integb16a is off the scale
I still have no idea on how to connect all vaccum lines for this swap. the intake manifold is a little different on b16 from b18, got a diagram for a crx but still didnt help, map censor and solenoids connect in different places. has anyone done a b16 swap into a 1990 teg with a diagram or a lot of knowledge on this vaccum problem???????need help-want to get it running!!!!!!!!
90integb16a is offline   Reply With Quote
Old 05-13-2003, 07:06 AM   #2
Rep Power: 17 DA69 is off the scale
well i have a ls/vtec with a b16a head. i wound up place t fittings on some of the vacum lines. i am also using my ls throttle boddy. on the back of the manifold there is only one place for vacum and the ls intake has 2. so i placed a vacum t and used it so i could take 2 vacum line and place it into one. how does your motor run right now. is your fuel pressure regular hooked up with a vacum line and your map? those are really the main 2 items you need to have hooked up to have that puppy idle right. good luck
Confusous say....It feels great to take off pants and jacket
DA69 is offline   Reply With Quote
Old 05-13-2003, 10:58 AM   #3
Rep Power: 0 mrpeabody is off the scale
my friend and I did the same swap in his 90' rs. I'll see if I can get a pic for you.... great motor to use....
mrpeabody is offline   Reply With Quote
Jdm Obd0 B16 Complete Swap 7thgen01 HYBRID -> EG-EK / DC 2 10-29-2009 01:43 AM
b16 swap dragon2003 HYBRID -> ED-EF / DA 11 07-01-2004 03:22 PM
89 CRX B16 swap links URNVS HYBRID -> ED-EF / DA 2 06-18-2004 04:14 PM
fs b16 swap , itr head so cal stella99si Parts: For Sale/Trade/Wanted 3 06-09-2004 11:51 AM
SoCal: FS: JDM B16 swap OBD-0 with extras assman Parts: For Sale/Trade/Wanted 0 04-08-2004 02:20 PM
