#3 | |
Admin with a big stick
Ride: 2003 S2000
I was gonna start a new thread about a stroker kit but i found this instead. I was wondering what kinda gains would one see from the Crowner Stroker kit for a B16A. It says that it will bump up displacement to 2.0, will that give some decent gains? Also are there any other companies that offer better kits for the same amount or a bit less cuz this kit is kinda pricy?
#6 | |
2265787829
Ride: Refer to my name, dumbass.
[/b][/quote] I thought about it after I posted it then I searched and forgot to post that. |
#7 |
Well what if we want to keep our b16. I would rather stroke my b16 then go ls/vtec i like my extra oil squirters or how ever you spell it. I was thinking of getting the golded eagle stroker kit personally
93 Si HB, B16A swap OBD1, GSR hydro tranny, 6 puck clutch,`1 Nitrous Express NXL 60shot ,Front and Back Strut bars, 99 Si rims, 2.25 Exh w/ flowmaster axle back, Ebay Short Shifter, Ebay intake, Megan Type R replica 4-1 headers dynoed on old tranny and stock clutch was 137 WHP and 177 w/ nitrous Our rides are dubbed rice burners because we aren’t housing some outdated, pushrod,gas guzzling, carbureted, iron-block V-8 engine under our hoods. What out industry has takes a lot more technique. Forcing 250 HP out of a tiny 1.6L engine.... Now look where the so-called rice burners are. Four-bangers are spinning more then 1,000 hp on the dyno and knocking down Pro stock-like times down the quarter-mile. |
#9 | |
Ride: 2003 S2000
Run coated forged pistons- you won't need the squirters then. Hell, just run forged pistons- you still won't need them. <!--QuoteBegin-joesbadcrx@Sep 22 2005, 08:16 PM Well i found out that I can use my gsr crank and rods but do i use the b16a pistons or the gsr pistons. Help me out here on making this b16a a stroked b18 [/quote] Nope, you can't do that either. You could use the GSR crank and rods, but that would require custom pistons to fit into the B16 without slamming the pistons into the head. __________________
#10 |
my name is Dale
why not just sleeve it to 84mm. about the same price as a stroker kit and can still rev the bitch to 11k lol
03 mustang mach1, procharged, built motor, 6sp swap, built rear. 525whp @9psi 00 cbr 929rr 420 conversion -1 +2 |
#13 |
Ride: 88 Honda Civic HB
<div class='quotetop'>QUOTE(joesbadcrx @ Sep 26 2005, 11:36 PM) Quoted post</div><div class='quotemain'>
So i can run the b16a pistons with the gsr crank and rods and i'll be fine. [/b][/quote] How many times does everyone have to say "no"?...that combination wont work(GSR crank/rods+B16pistons in a B16) unless you get a deck plate thatll turn it into a B18 anyways or a Tech43 Piston Kit(requires rebore). I dont think the head will even bolt on if you tried that GSR crank/rod w/oem piston setup in the B16. __________________
#14 |
HS Troll...And Mod
Ride: 2001 Honda S2000
rebore isnt that expensive...but i think i might be getting a discount since my friend owns an engine shop.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
