B16a2 Head On B18c
Closed Thread
Old 04-19-2003, 03:27 PM   #1
viciousracing
Guest
Posts: n/a
hey wassup guys, i'm building up a new project. I'm planning to swap in a B16A2 head on a B18C block. i will be needing some answers. Since the head will be going to the B18C, i would be using the B18C head studs right? and using the B16 distributor? Will there be any machining or conversions such as dowell pins, oil line, head conversions? which ECU is preferrable for this setup? will B18C stock header bolt to b16 head? since i'll be running all motor, will the Y80 or S4 be better? i want LSD and leaning towards the Y80. does skunk2 makes ITR IM for B16? anything will help. thanks guys.
Old 04-19-2003, 04:33 PM   #2
sohcslammer's Avatar
Rep Power: 35 sohcslammer is an unknown quantity at this point
Ummm, why would you swap a vtec head onto a vtec motor? Unless you just got a deal on a b18c shortblock. Are you sure you mean b18C?
Latest project -
1 fucking fast 99 SI
sohcslammer is offline
Old 04-21-2003, 12:33 AM   #3
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
naw dog use the b18c. period.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
K2e2vin is offline
Old 04-21-2003, 01:23 AM   #4
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
i dont believe there is any dowel pins to move. get a hondata for tuning it yO
pills_PMD is offline
Old 04-21-2003, 01:44 AM   #5
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
a b16 head on a b18c block is basicly a type R set up....
use the obd ecu that your going to be running, i.e. if you are running obd2 use the b16a2 ecu, if you are running obd1, use a P28 or P30... Also use b16 head studs, b16 dizzy and all that stuff...
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline
Old 04-21-2003, 11:17 AM   #6
viciousracing
Guest
Posts: n/a
Why put a B16A2 on B18C? The head ports are better by far than the B18C head, much similar to the C5. With a good port and polish with some tuning on the head, i will run pretty good with a 12.5:1 ratio. so this is WHY, i choose this setup. Through my research, i heard that the B16A2 head studs are too short, thus you need the B18Cs, because it'll screw down all the way. on the ECU, i'm leaning towards the P30, i don't wanna spend more money on chipping the P28, though the P28 is not recommended to run this setup. but the p30 is a gupper to find. i'll post my setup for the head, see what you guys think. BTW, will it lower my compression?
Old 04-21-2003, 11:38 AM   #7
viciousracing
Guest
Posts: n/a
here are the setups for the B16A2 head:
Toda spec B cams (it's a little better than skunk2 stage 2)
Toda Dual Valve Spring and Retainers
Skunk2 adjustable cam gears
Skunk2 valves (coatings are great!)
Port and Polish
Skunk2 ITR intake manifold
AEM Cold Air Intake
4-1 header
This will be running on a P30 Mugen N1 ECU.
Old 04-21-2003, 02:53 PM   #8
p30 mugen n1?? gay.
with all that work you're going to cheap out on the tuning?? generic ecu chips make you slower.
Old 04-22-2003, 10:51 AM   #9
viciousracing
Guest
Posts: n/a
that's perhaps the only ecu i could find now that's a P30. what do you recommend Pills, since your one of the ECU master magicians? hondata? i know hondata is great, but i have a hard time tuning it, i know jack shitty about it. the other one that i'm kinda leanin to is skunk2.
Old 04-22-2003, 11:07 AM   #10
viciousracing
Guest
Posts: n/a
what about P2T?
Old 04-22-2003, 12:58 PM   #11
the generic chips just don't work well.. they run near 11:1 a/f ... chet's dyno's prove that the skunk2 chipped p28 made less power than a p30.
i would do a p28/hondata , but if you have trouble tuning it.. pay someone to do it that you trust.. an hour of dyno time w/ tuning should be no more than 200 and you'd have a great
Old 04-22-2003, 02:59 PM   #12
viciousracing
Guest
Posts: n/a
i really don't know which to take, P30 or Chipped P28. i have enough money to buy two ecu's right now, i think i'mma buy the Hondata P28 and hondata P30. I'll see which one is better, and then try to sell the other one. But another question, by putting on the b16a2 head, will it lower my compression because i was running on a 12.5:1 with the B18C head?
Old 11-13-2006, 07:26 PM   #13
SiR_crx's Avatar
Ride:  2002 Scooby WRX
Rep Power: 8 SiR_crx is on a distinguished road
i realize that this is like 7 months later but the b16a2 head is a better choice if you use a b18a/b block, you have to move a few dowels, and make a v-tec oil line and get the correct electronics for it, but none the less read a few books on it, and call a few companies, don't always trust what you read / are told on the internet, most of it is just a lot of opinions with no history or experience with the questions you are asking.... just my opinon.....
hondas > muscle cars
SiR_crx is offline
Old 11-13-2006, 08:30 PM   #14
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
4-22-2003
http://pandora.com/
formby is offline
Old 11-13-2006, 08:32 PM   #15
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
It's still 2003?
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline
Old 11-13-2006, 09:24 PM   #16
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
The original poster doesn't even have an account anymore...
Calesta is offline
Closed Thread
Question: B16A2 head vs B18C1 head blacksi772001 General Tech and Maintenance 5 04-06-2009 07:55 PM
I think I found it! B-18Hatch Members' Lounge 8 08-08-2003 12:12 AM
Sir Head On My B16a2 Pewble HYBRID -> EG-EK / DC 3 03-29-2003 04:31 PM
b16a or b18c head ekPhred Engine Building 7 11-12-2002 05:11 PM
