b16a2 head on a b18c1 block
Old 10-15-2003, 08:14 PM   #1
Rep Power: 13 95integra gsr is off the scale
Send a message via AIM to 95integra gsr
i heard about this last weekend, i heard that the vtec on a gsr head kicks in at 4700 and the again at i think 7000, kinda like a lil bit 1st then the rest at 7000 (correct me if im wrong), and i heard the vtec on the Si head kicks in all at once, i wasnt sure about it, like i said, i heard this just last weekend, and i was wondering if anyone had heard of this, or if its B/S
thanx
daniel
95 auto ls
99gsr 5spd swap
Lifes short drive hard
95integra gsr is offline   Reply With Quote
Old 10-16-2003, 02:20 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Originally posted by 95integra gsr@Oct 15 2003, 07:14 PM
its B/S
Yup
Old 10-16-2003, 02:25 PM   #3
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
The OBD1 GSR with the B18C1 the VTEC crossover is at 4400, the secondaries open after that.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-16-2003, 08:19 PM   #4
so its pretty much b/s?
95 auto ls
99gsr 5spd swap
Old 10-16-2003, 08:31 PM   #5
crossover at 4400rpm and I thought butterflies at 5700rpm or is it 4400 butterflies and vtec crossover at 57k??
either way, it's a similar head, the ecu controls it
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 10-16-2003, 09:54 PM   #6
lsvtec's Avatar
<-- B16 head with P72 ECU, The X over is at 4400. ITR cams make the change much more audible than GSR cams.
Old 10-16-2003, 10:08 PM   #7
Rep Power: 15 96coupeb18 is off the scale
I have a GSR and my VTEC secondaries open at 5700-5800RPM that when you can really here and it actually picks up. Sucks though cause GSR's dont make all its power until 7600RPM Hopefully the turbo setup well help the car get into that powerband very quickly.
96coupeb18 is offline   Reply With Quote
Old 10-16-2003, 10:29 PM   #8
Rep Power: 27 SleEPeR_CRX is off the scale
that frankenstein is also called a poor mans type R. my friend has the reverse a b16b block with b18c1 head, and launches at 9000RPM. a bone stock engine in a gutted eg hatch running 13.8
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs &amp; Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 10-16-2003, 10:31 PM   #9
Rep Power: 27 NoJokE is off the scale
Send a message via AIM to NoJokE
What would be the point of putting the b18c head on? The B16 heads flow better, unless he had a fucked up head and had to put the b18 head on.
T3T67
<a href=\"http://www.hondaswap.com/forums/index.php?showtopic=69573\" target=\"_blank\">Buy my MSD 6AL, Carsound Cat, VTEC Distributor!</a>
<a href=\"http://ipods.freepay.com/?r=11169222\" target=\"_blank\">Sign up for a Free Ipod!</a>
NoJokE is offline   Reply With Quote
Old 10-17-2003, 12:19 AM   #10
lsvtec's Avatar
Not quite, VTEC hits at 4400 RPM and your secondaries in you IM open around 5700.
Wow, imagine what he could run if he learned to drive.
Old 10-17-2003, 04:08 AM   #11
the guy that ownz the b16b with b18c1 head says to say, that the reason he does that is b/c the combustion chamber on the GSR head is different bumping up the C/R, and he says it makes no torque, only rev's high, so he has to get off the line with a good 60' to get a good run in. he also says he'll challange u to a race anyday.
1990 CRX Si
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Old 10-17-2003, 04:18 AM   #12
Rep Power: 0 93SiRII is off the scale
heres what goes on, the p72 ecu, engages vtec 2 4400 rpm, then the secondaries at 5700 rpm
the reasn you wont hear vtec is because the transition in the powerband is so smooth, where as at 5700 its totally differnt.
as sleeper_crx said:
if your going all motor you want rpm, theres no torque in a all motor setup.
first off who are you to say i cant drive?
second, i have a dresser full of timeslips to show i know how to drive so shut up
i dont know if you know this but, the b16 piston has a dome shape to it, and the gsr is a flat top design, so makes a smaller combustion area, higher compression.
yea the b16 head flows better, but not by much. also how many stock b16s out there are running 13's?
heres my setup, and you be the judge lets see who can drive
b16a
GSR head
short ram intake
kamakazee header
2.5" exhaust
skunk2 cam gears
CTR intake cam
very basic setup, its all driver
93 Civic w/b16a 13.6@97 mph, 1.80 60&quot;, .595 rt
93SiRII is offline   Reply With Quote
Old 10-17-2003, 02:48 PM   #13
lsvtec's Avatar
Quit while you are ahead, just shut the fuck up.
b16a head + jdm b18c1 block???? 2rbo HYBRID -> EG-EK / DC 2 07-27-2004 08:54 PM
B18c1 block with b16a head civichbgsr Engine Building 8 06-17-2004 07:16 PM
Gsr Head B16 Block (w/ctr Pistons) 92' ls-vtec Engine Building 8 05-04-2003 02:44 PM
B16a2 Head On B20 Block 99B16Hatch HYBRID -> EG-EK / DC 2 01-16-2003 03:05 PM
