#76 | ||
Honda Enthusiast
Ride: '94 EG sedan w /Z6, '97 EK hatch
Max? There is no max. Max just means you gave up. This is my thread: http://hondaswap.com/engine-building...g-wind-110848/ http://hondaswap.com/members-lounge/...thread-278554/ Quote:
#77 | |
Honda Enthusiast
From what I have just learned, Nitride coated valves are good, if you get them coated after a three or five angle valve job. They should not be coated before. Does anyone know anything about that?
Also, from what I understand, over sized valves provide a better seal and allow for more power to be made later on. Is that really the case? I'm wondering if I should go with over sized, since later on I may want to increase my power goals. If I did, would a .5 or 1.0 over size valve work better and why? __________________
#78 | |
Honda Enthusiast
Is putting your head (not the one connected to your neck bone) on a flowbench really worth it for this kind of build or would that be better suited for the pros trying to make as much horsepower from their build?
#79 | ||
Honda Enthusiast
I will definitely do that when I get my head ported. I'm sure the machinist will let me know how that will help me out later on. __________________
#80 | |
Honda Enthusiast
What does the term "tulip" mean when it refers to the valves?
By the way all, the link Blanco posted Question about Oversize Valves: Nissan & Infiniti Engineering Talk: Nissan Forums / Infiniti Forums - NICOclub will really help answer questions about over sized valves and any advantages/disadvantages for you. It did for me anyways. ![]() __________________
#81 | ||
Honda Enthusiast
#82 | |
Honda Enthusiast
Would a "block guard" be a good idea for this type of build? Granted, since I am giving myself such a long time to complete it, my goals will most likely be upped a tad.
Also, what is the function of a block guard?__________________
#83 | ||
Honda Enthusiast
On a side note (it's been a while since I've had one of these) my boss just called me and told me that because the volume is down (I'm a Supervisor at UPS and the volume is down by 467,000+ pieces) my hours on the only day I was able to make overtime have been cut. What does this mean to me? Well, I have to be REALLY careful on what I buy for my build and yes, it puts a SEVERE hindrance on my build, period. *sigh* It's depressing, but I'll figure something out. A second job is looking like the only solution to this problem. However, a second job will also hurt a lot, like it did before, and will mean that I will not have any down time, or time to breathe. *double sigh* Now I'm REALLY contemplating parting out my block, just to help things out for a bit. Though my hour cut is not permanent, it will hurt as long as it will last. (right now it's looking like a month and a half to two months) __________________
#84 | ||
Honda Enthusiast
Yes, that's right, my stupid ass was only half way into buying parts when the proverbial "shit" hit the fan. I did manage to snag a full D swap and an Si tranny for it, but as far as the B goes, yeah, I only have the head and block. Plus, I never mentioned this before, but the head does not have anything from the valve train in it besides the valves and is currently sitting in the back room in quite a few pieces. Cutting back is exactly what I'm going to have to do and just embellish myself in a ton of research for a while. This, as you know, is something I do not mind doing at all.__________________
#85 |
The name's Sam
bummer man sorry to hear your hours got cut. that shit sucks! What all parts do you have with the b16 block you have right now? Sorry if I missed where it was posted.
Parts for sale: http://hondaswap.com/parts-sale-trad...-parts-115446/ Build Threads: Civic: http://hondaswap.com/civic-del-sol-eg-ek/d16y8-n-build-112401/5.html Trans Am: http://hondaswap.com/other-vehicle-discussions/1980-trans-am-build-thread-oh-yeah-its-official-149941/#post1054318 |
#86 | |
Honda Enthusiast
I think it was posted in page three or so. Eh, it's all good. I have an almost complete JDM B16 block (it's missing the alternator) with Eagle rods and no pistons yet. I may part out the block. I'm not sure yet. That's about it.
#87 | |
Honda Enthusiast
From what I have been reading lately, it seems like any ECU that is "chip-able" would work for this set-up. The reason for this is once the build is finished (ten thousand years from now) the tuner will be able to chip and re-program it. Now then, since I will be running OBD1 or rather, an OBD1 conversion, would a P28 do as good of a job as say, a P30 or a P72?
#88 | ||
Honda Enthusiast
#89 | |
Honda Enthusiast
Someone please tell me the difference between H-rods and I-rods. Thank you.
#90 | |
Honda Enthusiast
I believe so. Would it be about preference on the design or is one better or stronger, if you will, than the other?
#91 | ||
Honda Enthusiast
![]() ![]() ![]() ![]() __________________
#92 | |
Honda Enthusiast
Here are the specs to the Skunk2 stage 2 turbo cams I would like to run in my set up...
Intake Duration/ Lift: 231°/ 11.0 Exhaust Duration/ Lift: 236°/ 10.6 Intake Center (ATDC): 104 Exhaust Center (BTDC): 110 Clearance Intake/ Exhaust: .007'/ .008' Now then, I believe it might have been LSVTEC who told me that he ran GSR cams in a turbo set up and made well over 500+hp. (I think he said that somewhere in my thread. haha) I know for a fact that when choosing cams, you need to pick them out for your specific application. With that said, how would GSR cams compare to these? If anyone has specs on those I would greatly appreciate it. Sorry for not posting this question before when the topic was being talked about, but I just thought about it. Gracias. ![]() P.S. I'm still trying to figure out the duration/lift in cams, so please bear with me. __________________
#93 | ||
Honda Enthusiast
#95 | |
Honda Enthusiast
I'm a Google-a-holic when it comes to searching for things. It's a great tool to use, something I wish SOME people would actually learn to do and.... ![]() Asshats I tell you. Lazy asshats. *raises eyebrow* Never mind? Ask, talk darn you, TALK! SAY IT! I would like to know what was on your mind. Had you REALLY not wanted to say anything, you would have just deleted your post. You obviously have something on your mind my friend. Please, chime in. I promise *cocks shotgun* not to hurt you for *loads bazooka* posting in here. *aims at face* At best we might both learn something from each other. *readies death ray* So please, feel free to speak freely. *sets charges around 'submit reply button'* |
#96 |
Honda Enthusiast
OH! Something that I've been wanting to ask and learn about for a LONG TIME! Oil squirters! I know that GSR blocks have them, not really sure if B16's have them (which I assume that they would since it's almost the same darn thing) and know that B18a/b's and B20's don't have them. I think I have a slight idea what their function is, but please, someone enlighten me. What is their primary purpose and how can say, an LS/VTEC survive without them?
I ask because nothing is edged in stone as far as my block goes and the temptation to get my hands on a B20 block is always there, though I already have a B16 block with Eagle Rods to start out with. (I think I'm leaning towards a GSR block in the end. At least that's what the voices keep on telling me.) |
#97 |
is lol'ing @ you
I read once that oil squirters can actually become a problem because under high stress circumstances they can blow a small amount of oil up past the rings into the chambers. Is there any truth there?
#98 | |
Honda Enthusiast
#99 |
The name's Sam
couldn't tell you about that but ls/vtecs stand up well without the oil squirters. Especially if you go with forged internals. I may not have mentioned it in here but a buddy of mine is runnin a b20 block and b16 head almost the same build you have goin except the cams. and he has had no problems. awesome car just with the head build, he still plans on goin with forged internals then slappin his turbo kit on but if anything craps out til then I will let you know what, how, and when so you know.
#100 | |
Honda Enthusiast
| B16a2 Head On B18c | viciousracing | Engine Building | 15 | 11-13-2006 09:24 PM |
| I think I found it! | B-18Hatch | Members' Lounge | 8 | 08-08-2003 12:12 AM |
| vtec head and turbo or b16a2 for a 99 dx hatch? | racecarl | Engine Building | 3 | 08-07-2003 03:27 AM |
| Sir Head On My B16a2 | Pewble | HYBRID -> EG-EK / DC | 3 | 03-29-2003 04:31 PM |
| B16a2 Turbo Engine Build | JDcompman | Engine Building | 4 | 02-06-2003 12:44 AM |
