B16a2 valve springs in a 99 ls head
Old 12-18-2003, 01:10 AM   #1
Rep Power: 16 Sed8ed is off the scale
Send a message via MSN to Sed8ed
A little while back it was suggested that a good low budget setup for an ls head would be itr intake valve springs and moving the existing intake springs to the exhaust side. These combined with a mild grind on the stock cams (I prefer grinding due to the existing proven base circle and for price reasons). I have a set of b16 valve springs and retainers out of my car lying around and I was wondering if they would be an exceptable, noticable exchange for the itr springs. This setup is going back into my gf's teg since she is looking for a little more power than she has presently (combined with i/h/e and an safc and rc 310's)
I am open to thoughts and suggestions but keep in mind that we have a budget of $1000 for all and the springs, retainers, intake and rc 310's are existing
'Due to budget cuts, the light at the end of the tunnel has been turned off.'
'Out of my mind, back in five minutes'
Originally posted by simba
Canada didn't become a communist state, it became a socialist country run by liberal housewives who think cause and effect is black and white.
Own a gun? Well, it's probably going to cause someone to be shot sooner or later. Better restrict them.
Own a fast car? Well, you're probably going to kill someone due to driving too fast sooner or later. Better give the police unlimited power to "convince" you to return it to stock, so you won't kill anyone. Freedom is subjective.
Sed8ed is offline   Reply With Quote
Old 12-21-2003, 11:48 PM   #2
Anyone?
Old 12-22-2003, 09:00 PM   #3
Rep Power: 12 SeanJohn1802 is off the scale
Send a message via AIM to SeanJohn1802
b16 and b18 (Si and Type R) intake springs are the same... but the exhaust side on the Si is weak, only a single spring (or i forget what its called) as opposed to the Type R exhaust side is also dual spring . . just like the intake side. .
Retainers on both are the exact same thing, no difference what so ever. . so if your keep your stock redline, Si springs would be just fine. . . i dont think you'd even have to spend money on retainers, but im not sure about LS heads as not too many people try to supe those up at all...
<span style=\'color:red\'><a href=\'http://forums.clubsi.com/showflat.php?Cat=&Board=UBB43&Numbe r=3915947&page=0&view=collapsed&sb= 5&o=&fpart=1\' target=\'_blank\'>My Feedback Thread</a></span>
SeanJohn1802 is offline   Reply With Quote
Question: B16A2 head vs B18C1 head blacksi772001 General Tech and Maintenance 5 04-06-2009 07:55 PM
Which Valves, Valve Springs and Retainers Ger_Mugen_Civic Engine Building 8 03-30-2004 11:35 AM
Want A High Revving Monster? maverick97 Engine Building 10 06-26-2003 04:25 PM
valve lash specs for Y8 (99 Ex) head? teal_dx General Tech and Maintenance 3 10-23-2002 03:18 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
