WRX Sellout
Ride: 2002 WRB Impreza WRX
Money's not an issue?
JDM ITR. ![]() But if those are your two choices, go with the GSR. No replacement for displacement. __________________
This space left intentionally blank. |
#6 |
WRX Sellout
Before you make any decisions, look at the prices. The B16b is just a tuned regular-old B16. If the price is way higher than the B18, get the B18. You can always upgrade the B18 yourself with comparable parts.
#7 |
Admin with a big stick
Ride: 2003 S2000
Get the B18C. Like dohcvtec said, there is no replacement for displacement. The B16B would be nice to have just so you can say you have it, but that's about the only reason why I would buy one.
#8 |
the b16b is a detuned JDM ITR, same exact block, different than the b16a. the gsr will have more on the bottom end, the b16b doesnt get happy until it is around 6.5k. if street and drag is where u are driving the most, then the gsr makes more sense.
Used performance parts straight from Japan/road race questions: <a href=\'http://www.rcrewracing.com\' target=\'_blank\'>www.rcrewracing.c om</a> |
#9 |
How did you blow a B16A2 that is 2 years old?! Trying to get to 100 in 2nd gear?!
*EDIT* A boosted B18C1 is a force to reckon with, forget LSVTEC *EDIT* __________________
My skin is singed but it heals my heart and with glowing pride I'll wear my scars. I'm honored by your hatred! She wanted love, I taste of blood. She bit my lip and drank my warmth from years before. |
#11 |
the block isnt port and polished that is the head. the head design yes is similar, with the minor port and polish, and differnt valve train, valves, springs, cams ect.
the block is from a completely different cast than the b16a, the b16b and the b18c share the same exact block, that is why u can drop all b18c internals into a b16b to stroke it to a 1.8l using all oem parts. __________________
#15 |
chris, are you saying a b16b block has the same bore as a b18c block?
and have any of you ever seen ctr pistons? the reason a b16b makes 185hp is the size of its pistons and duration of its cams. __________________
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
#17 |
BINGO!
http://asia.vtec.net/beystock/honda/civicr/ :edit: another good one: http://raceseek.com/honda_specs.htm __________________
.....deagle..... |
#18 |
Ride: 2003 S2000
Yes, all B series have the same bore except the B20... that info is in our reference section too.
![]() __________________
#19 | |
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#20 | |
yes i have seen ctr pistons, they are mini-Mt. Fuji's. there are alot of reasons that the ctr makes 180hp. that can be seen as too little, compared to the itr are a good amount if compared to the b16a. the cams have more lift than the itr as well, the intake mani, 2.5 collector, that all adds to the total in the end b16: u are right the crank does produce a shorter stroke, the rods also help with that __________________
#21 |
RETIRED
how does rod length have anythign to do with it?? whether my rod is 4 inches long, or 40 inches long, the TRAVEL is still dependant on the crank's stroke.
#22 | |
Member of the 20 nut club
hmmmm theres a whole lot of talk about "rods" and "stroke" goin on here ... seems pretty
to me__________________
МОΛΏΝ ΛΑΒΈ |
#23 |
chris, i misunderstood you.
what you said is correct. __________________
#25 |
RETIRED
Bringing dead threads back for the sake of adding zero value comments is a bad thing. Please refrain from doing so in the future.
Thread locked to prevent further post whoring. ![]() |
| b16b head | 96IntegGSR | HYBRID -> EG-EK / DC | 6 | 12-06-2006 07:55 AM |
| B16B into an EG Hatch | Chris_Gee | HYBRID -> EG-EK / DC | 10 | 05-12-2006 12:50 AM |
| B16b install in a EE8 crx vtec | clanny | HYBRID -> ED-EF / DA | 13 | 10-26-2004 05:21 PM |
| B16B stroker | CRX_B16B | Engine Building | 28 | 10-22-2003 01:37 AM |
| B18b Or B16b | ECTuner | General Tech and Maintenance | 21 | 02-14-2003 10:58 AM |
