B16b vs b18c5 piston
Old 07-22-2008, 06:31 PM   #1
loko123 is on a distinguished road
Default B16b vs b18c5 piston
Hey just wondering what piston should i get and will be better on my b18c1 block and i'm going all motor and wich will give me more power?
loko123 is offline   Reply With Quote
Old 07-22-2008, 07:05 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
Probably the B16B.
Old 07-22-2008, 08:28 PM   #3
i thought about that but wouldn't my compression be too high like around 13. compare to the ITR piston that will give me around 11.5
Old 07-26-2008, 12:43 AM   #4
Calesta's Avatar
Ride:  2003 S2000
Too high for what though? Maybe normal tuning on pump gas, but you didn't specify.
Old 07-26-2008, 12:39 PM   #5
high for running on pump gas like 93 octaine i heard the compression will be to high with CTR piston compare to the ITR i heard. and i don't want to run with race fuel just on regular pump gas like 93 octaine.
Old 07-26-2008, 12:47 PM   #6
I'll be back...
B16RacerN2NR's Avatar
Ride:  96 DB8, 06 Mazda 5
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
So then what was the point of asking which will give you higher hp numbers? You already seem to have your reason for not wanting to run the CTR pistons... That leaves only one of your choices left...
Also, B16b pistons will put a b18c1 at a hair above 12:1 compression assuming you stay with the stock stroke length, don't mill the head, ect...
USDM ITR pistons will put your B18c1 around 10.8:1
JDM ITR pistons will put your B18c1 around 11.4:1
I got these numbers from using this caculator if you wanna try it yourself... http://www.c-speedracing.com/howto/c...c/compcalc.php
Mercedes-Benz STARt program, here I come...
B16RacerN2NR is offline   Reply With Quote
Help choosing B16b stroked to B18C5 or B20/B18C5 Escabar HYBRID -> EG-EK / DC 3 10-12-2007 11:12 AM
b16b ctr piston in b16a conrod eater_eg6 Engine Building 2 10-26-2005 08:35 PM
b18c1/b18c5/ls-vtec/b16b/zc MrTokai HYBRID -> EG-EK / DC 3 01-01-2004 02:35 AM
B16b Or B18c5 Tek-C HYBRID -> EG-EK / DC 14 06-19-2003 10:04 PM
B16b Vs. B18c5. 98 Civic Lx 4dr 5spd wutnot HYBRID -> EG-EK / DC 17 02-15-2003 12:20 AM
