After reading on Endynes' site of the filling in (welding) in the chamber to raise compression.
What do you guys think of removing the seats by heating the head enough to loosen them, then welding up, then heat treating back to spec after re-installing the seats. Just a thought. Probably cheaper to have custom rods/pistons and a block guard to raise comp instead. E __________________
"If you can read, thank a teacher" "If you can read it in English, thank a VET" |
Ride: 1997 Integra
HMT has a tech article about welding up the champers on a D-series. A6 if I'm not mistaken. Welding a head is extremely difficult though. Not only is it aluminum, but it sweats.
![]() Like water on a duck's back, just let it roll off... |
Yeah, I've welded alum before. But like cast iron on thick sections or large pieces, you should use a heat stick/marker to get it up to temp then you can get to weldin, and it 'flows' alot better. And if you use a MIG, you don't get that much 'glass' to grind off.
I wanted to do this years ago to the EW 12 valve heads but then the D16a1 piston was tons cheaper to raise comp. Now that I'm thinking of it, there really isn't much room to 'fill in' around the valves anyhow without shrouding them.. Nevermind.. E __________________
Ride: 88 Honda Civic HB
Most people just weld in quench pads. You don't really want to weld around the valves since it'll just shroud the valves.
Biggest issue with welding the head is the head warping. __________________
#5 |
OK, I just had an kinda obvious Idea.. What about sticking with the B18 head on the B20 block and that would give you about (theoretical)1.5mm extra around the circumference of the c-chamber right? Now that being said, you should be able to do lots of un-shrouding of the chamber and use the B20 head gasket.
I wonder how much you could dig out around the valves?? I'll have to take some pics of the b18 head from the crank end of the cyl and scribe it. I'll ask my son if he can get his little hands in there. I know that now i'm changing the topic toward increasing the c-chamber but then there would be more room to weld.. E __________________
#6 |
B20 already has the same head as B20A/Bs; the circumference of the B20A head is 81mm.
1988 Honda Civic Standard-more mods than I want to list 1992 Honda Accord LX 1996 Toyota Avalon-Spun bearing, for sale. Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 Last edited by K2e2vin; 11-08-2009 at 09:36 PM. |
#8 |
I'd really not mill the head too much, it retards the cam timing and could lead to premature crackin. Especially if you get too close to those little 'nubs'.
Just last week my machine shop buddy gave me some high domed pistons that someone dropped off and never picked up for months. They are coated on the skirts but I don't know if it will raise the comp too much with the B18 head. I took the rings off and it slid in the B18 block nicely, with little resistance. I need to put them side by side and take a pic. I don't have the barretts or know how to measure the volume of the dome with it pokin out the top of the bore. I wonder how much could be milled off the crown of the piston?? E __________________
#9 | |
seņor member
Ride: 95 Teggy
Tired Of Having My Car Broken Down Will Some One please Slap Some Knowledge In My Head? Reptiles Rock! |
| Welding | Z6CRX | General Tech and Maintenance | 12 | 03-11-2009 08:21 PM |
| Welding How To. TIG Welding Intro | MikeBergy | Body / Exterior / Interior / Cosmetics | 5 | 07-28-2006 09:40 PM |
| Spontaneous Human Combustion | Airjockie | Members' Lounge | 23 | 05-12-2006 02:44 PM |
| D16Z6 Combustion Leak Confirmed | jisakson | General Tech and Maintenance | 3 | 04-27-2006 11:38 PM |
| 240 Psi Combustion Pressure | steelbuster | General Tech and Maintenance | 9 | 04-27-2003 11:32 AM |
