b18 head choice
Old 03-14-2005, 10:27 AM   #1
Rep Power: 0 sparky is off the scale
Unhappy
Alright guys. I'm tryin to figure out which head would be optimal for the engine building. Im currently building a turbo b18 engine... i am in the midst of buying a built dart block and I am wondering what head choice would be the best. I know my options are a b16 head, b18c1 head, and a b18c3. From what i have read the b8c3 has a better valvetrain as well as it being "tuned and ported to perfection". Any info would be appreciated. Would it be cheaper to just buy a 18c1 head and p&p and upgrade the valvetrain(obviously cams too). Thanks Jason
sparky is offline   Reply With Quote
Old 03-14-2005, 10:40 AM   #2
If you are dropping the cash on the Dart Block, get the Dart Head as well. It's ported better flows better and is based off a GSR Blank.
Brian
90 Integra Sedan
B20V 225 / 153
Old 03-14-2005, 10:41 AM   #3
alright thanks
Old 03-14-2005, 10:42 AM   #4
As far as valvetrain... if you arent going for crazy perf. #'s... stick to OE ITR shit. It's engineered to last... so use it.
90 Integra Sedan
B20V 225 / 153
Old 03-14-2005, 10:55 AM   #5
Rep Power: 26 projectxspeed is off the scale
Send a message via AIM to projectxspeed Send a message via Yahoo to projectxspeed
You are better off buying a b18c1 head (GSR). While the type-R does have a mild p&p its not designed well for high HP. The valve train + cams are better but aftermarket will take you a lot further than any OEM.
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a>
Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a>
projectxspeed is offline   Reply With Quote
Old 03-14-2005, 11:00 AM   #6
Which is why I suggest he tells us goals/budget.
90 Integra Sedan
B20V 225 / 153
Old 03-14-2005, 11:29 AM   #7
i apologize for not stating my goals. My target horsepower is 350-400. I want to build it right to be reliable. But yet why would i go overboard and spend more if i dont need to. Well I have the money to buy a dart head at this time also. I have a good 9k set aside for this engine. I dont wanna overdo myself but i want it to be as reliable as a turbo engine can be.. haha. thanks for your help guys, i really appreciate it.
Old 03-14-2005, 11:35 AM   #8
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
buy the dart head/block.....go to www.fullrace.com then to hondata.com....then to gearspeed.com and to hasport.com...and some gator axles......you're set with a bulletproof set up.....more than 350-400 possible 9k + though???? if i came across 10k thats what i would buy..
here is a good example of 9k invested
http://www.centralfloridaturbo.com/dynovideos.php
the gsr
http://pandora.com/
Old 03-14-2005, 11:38 AM   #9
Dont forget no matter what you do as far as building the engine you have got to get it tuned. Not getting it tuned right away is asking for trouble.
90 Integra Sedan
B20V 225 / 153
Old 03-14-2005, 03:51 PM   #10
i meant 9k on the engine meaning that I the turbo setup was not included. I dont know if that black integra on that site was 9k with or without the turbo setup. Yeah and im definately putting it on a dyno and getting it tuned as soon as its finished being built.
