b18 timing cover
Old 03-18-2009, 01:55 PM   #1
Ride:  94 Del Sol
Rep Power: 0 b18b1_delsol is infamous around these partsb18b1_delsol is infamous around these parts
Exclamation b18 timing cover
Will a ls b18 lower timing cover work on a b16?
b18b1_delsol is offline   Reply With Quote
Old 03-18-2009, 10:50 PM   #2
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Can't say for sure, but I'm pretty sure it will work. I've never tried this though, I would assume B-Series covers would have to be the same or else a timing cover for an LS-VTEC would not be possible.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 03-19-2009, 12:37 AM   #3
lower? i dont think they will as the deck heights are different.
90 Integra Sedan
B20V 225 / 153
Old 03-19-2009, 12:20 PM   #4
Rep Power: 5 thompy.mark is on a distinguished road
Yup, it should be a straight fit. Had covers from a b18b and b16a sitting next to each other, and were pretty much identical. As far as I can tell the extra material for the taller deck blocks is in the upper covers
thompy.mark is offline   Reply With Quote
Old 03-19-2009, 01:01 PM   #5
Ok, I wasnt sure. But I do know if the block/oil pump is from a (96+) and the timing cover is from a 90-95 you will have to trim the lower cover to fit.
90 Integra Sedan
B20V 225 / 153
Old 03-22-2009, 03:22 AM   #6
esi42's Avatar
Rep Power: 16 esi42 is on a distinguished road
1st gen b16a is the same as 1st gen b18a
2nd gen b16a is different than 1st gen b18a.
Ive never owned a b18b so I can say for sure on that one.
If you start from a false assumption, you may end up at a strange destination.
Quoth the server, '404'
esi42 is offline   Reply With Quote
Old 03-22-2009, 03:33 AM   #7
Ride:  EX EK Coupe
Rep Power: 4 DickBswapn is on a distinguished road
myspace
I have had issues with this. It depends on the oil pump. What B16, and what B18 cover?
DickBswapn is offline   Reply With Quote
Old 03-22-2009, 10:01 PM   #8
Ride:  94 Del Sol
00 b16a2 motor and 95 b18b1 lower timing cover.
Old 03-22-2009, 10:09 PM   #9
Like I said above, you will have to trim the lower timing belt cover in order for it to fit.
90 Integra Sedan
B20V 225 / 153
Old 03-23-2009, 02:39 AM   #10
Ride:  94 Del Sol
okay thanks
Tags
b16, b18, cover, timing
Need timing cover help ksphar HYBRID -> ED-EF / DA 7 01-11-2009 03:53 PM
timing belt cover?? sevenhillsbilly HYBRID -> ED-EF / DA 1 09-30-2008 11:15 PM
now my timing cover....... 92hprelude Prelude 2 09-24-2008 10:45 AM
WTB - LS/B20 Timing Cover brian11to1 Parts: For Sale/Trade/Wanted 2 11-27-2004 08:34 PM
WTB:timing cover 88civicHBz6 Parts: For Sale/Trade/Wanted 2 08-06-2003 05:50 AM
