Hey im building a ls/vtec b18a1 block stock internals with a b17 gsr head with type r cams i was wondering if i would have enough piston to valve clearance with this setup one more question i have is if i put p61(b17) pistons in the ls would i have more piston to valve clearance and more compression? and last but not least how hard is it to punch out the wrist pins or is it not possable in my own garage.
Ride: 88 Honda Civic HB
Yes, you should have enough clearance.
The B17 pistons will definitely increase compression but clearance will be a little closer. It should still work fine though as there are people using B16 pistons, which have larger domes, in LS-block setups with no problems. You can always clay it to make sure there's no contact with the piston and head/valves. The wrist-pins can't be "punched out" so to say. They're pressed in with a press, and need to be pressed out. Honda uses a special tool(used in conjunction with the press) that prevents damage to the piston. If you have a +5ton press, you can still do it in your garage. I was able to press mine out at a shop with a press by using a assortment of different sockets(not recommended!). When I had another shop do a different set of pistons, which did not have the tool, the pistons were messed up. The tool itself is very hard to find(I believe they only sell it to Honda shops or something). I had asked some shops if they could do it for me but they said they wouldn't press out the pins unless they worked on the block. __________________
Go for it dude! Let us know how it goes.
| FS: H22 head, cams, str cam gears, 2 h22 blocks eg, ek, cleaning garage. | h22pwrdcivic | Parts: For Sale/Trade/Wanted | 16 | 01-11-2009 12:16 PM |
| FS: Sleeved block, cams, head | ctechone01 | Parts: For Sale/Trade/Wanted | 3 | 09-24-2007 02:07 AM |
| B18A1 head build up questions | TRICK_Z28 | Engine Building | 6 | 08-10-2007 05:18 PM |
| piston to valve clearance specs and some other help needed | GSRCRXsi | Engine Building | 11 | 05-21-2006 09:00 PM |
