b18b build up
Old 10-02-2002, 12:41 AM   #1
Rep Power: 16 inspecta83 is off the scale
im building my b18b for about 12psi, i already did my clutch and flywheel and now i am workin on the motor. i plan on doing the valvetrain, pistons and rods and just wanted to know what yall would reccommend as far as namebrands, specs, etc. for these 3 mods and what other mods you think should be next on my list. thanks
"sunshine plays a major part in the daytime.....peace to mankind ghostface carry your black 9..."
inspecta83 is offline   Reply With Quote
Old 10-02-2002, 01:20 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
dont bother with valve train.
endyn pistons
eagle rods
nuformz block guard
and hondata
you will run 12psi no problem
Old 10-02-2002, 04:48 AM   #3
Rep Power: 15 sprfreek is off the scale
you don't think an entire ferrea valve train would benefit him? i seriously do .... your going to need part number IC1000 from the ferrea website
SRP or JE pistions
crower rods
aluminum block guard ( you could also weld it on, machine it smooth then machine holes for the water sleve.... but that';s over kill who wants that ??? )
and hondata stage 4b
sprfreek is offline   Reply With Quote
Old 10-02-2002, 12:14 PM   #4
well..under normal circumstances i would agree that i shouldnt bother with the valvetrain, but the valves on the motor are screwed up, so i have to replace them anyway, so i'm planning to get skunk2 valves, retainers, and springs. also, i know that the ls motor is not a high rev-ing motor stock, but i was just wondering what i could do in order to make it safe to rev high.
as for the hondata...i was plannin on getting a 2b
Old 10-02-2002, 01:14 PM   #5
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
SRP or JE pistions
crower rods
Why pay 2X the cost of Eagle rods for the Crower name? I would take the Endyne roller wave pistons over either of those listed. Hondata 2b will be sufficient if you know a shop near by with a stage 4 to tune yours.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-02-2002, 01:52 PM   #6
B16
B16's Avatar
if you're doing all that, you should be able to handle more than 12 psi, drop your CR to like 8.5:1
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 10-02-2002, 02:09 PM   #7
Rep Power: 15 LSvinny is off the scale
what about cams i herd the right cams can spool you up faster?
LSvinny is offline   Reply With Quote
Old 10-02-2002, 02:11 PM   #8
lsvtec's Avatar
Crower makes a turbo grind for the LS, I don't know anything about how they perform. I imagine that many cam manufacturers make a turbo grind for the LS, just do a little looking. The stock LS cams should be a fine starting point.
Old 10-02-2002, 02:17 PM   #9
who sells all this stuff and that wont jag you around
Old 10-02-2002, 02:31 PM   #10
lsvtec's Avatar
I don't know where you could get the cams from, I have never purchased non-Honda cams. You can get Eagle rods and Endyne pistons here.
EDIT: I am also unsure of the best place to buy a block guard.
Old 10-02-2002, 03:19 PM   #11
Rep Power: 15 PLRacer is off the scale
Send a message via AIM to PLRacer
how many psi at the most would u run on b18 with pistons rods block guard and honata?i know i would also need more than that.
PLRacer is offline   Reply With Quote
Old 10-02-2002, 04:33 PM   #12
lsvtec's Avatar
How much boost do you want to tune for?
Old 10-02-2002, 04:52 PM   #13
im thinking about 15-20. im trying to make up my mind if i should go b18 or b20
Old 10-02-2002, 07:01 PM   #14
i spent the whole day today lookin for a valvetrain (valves, springs and retainers) for my b18b that was all the same namebrand and i found out that only ferrera and crower make this valvetrain kit for my motor (i think crane does too). since ferrera is kinda out of my price range i was wondering what you guys think about crane since that is the only choice that i have. thanks
Old 10-02-2002, 07:15 PM   #15
lsvtec's Avatar
See the post in "What should I swap?"
Old 10-03-2002, 04:52 AM   #16
Rep Power: 29 knowledge is off the scale
Everyone want to know how much psi they can run with this or that! I will say this once! IT ALL DEPENDS ON WHAT SIZE TURBO YOU PLAN ON RUNNING! A TD05-12A@15psi pushes 320CFM's. A TD05/6-18G@15psi pushes 600CFM's. Almost twice as much! You could lets say run the 12A at 10psi safely, but once you swap it for a 16G (that pushes 505CFM's@15psi) you could only run it at 6psi safely. So from now on we need to see X turbo with Y motor! This would help get accurate info!
The C5 is strong with this one........
knowledge is offline   Reply With Quote
Old 10-03-2002, 05:05 AM   #17
RETIRED
to my knowledge, crower is the only turbo cam maker for the ls.
theres even less support for springs/retianers/etc for the ls head. why? its pointless. the ls was no meant to rev in the first place- so why do it? furthermore, why do you want to rev higher with a turbo? shift and make boost again. with the ls tranny, you will be in gear long enough anyway, and there's no vtec range to fall out of.
if you want more free flowing- focus on breathing- not valbve train. cams, yes.. springs, retainers, no.
also, if you are doing valves, as you said yours are shot- make sure they are done correctly. you can't just drop in new valves.
Old 10-03-2002, 05:48 AM   #18
You should use my post as a pin up b!
Old 10-03-2002, 08:29 AM   #19
Rep Power: 20 slohnda is an unknown quantity at this point
Send a message via AIM to slohnda
crane cams (www.cranecams.com) makes a turbo cam for the ls. its their stage 3 'number #14' cam.
Turbo applications
This profile features our unique ”split duration” lobe profile design (exhaust duration is less than intake duration), ”spools” turbo faster for quicker boost/response
Reduces turbo lag time
Strong mid to upper rpm range when boost applied
Use intercooler and low restriction intake/exhaust
Use new valve springs
RPM range 1,500-7,500
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (pissedoffsol @ Nov 13 2002, 01:04 AM)</td></tr><tr><td id=\'QUOTE\'>its cool- i know im hung like a chipmunk</td></tr></table><div class=\'signature\'>
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (Silverchild79 @ Apr 3 2004, 11:10 AM)</td></tr><tr><td id=\'QUOTE\'>ewww that even made me not like pussy</td></tr></table><div class=\'signature\'>
slohnda is offline   Reply With Quote
Old 10-03-2002, 12:58 PM   #20
nice!!
Old 10-03-2002, 09:54 PM   #21
Originally posted by knowledge+Oct 3 2002, 03:52 AM--><div class='quotetop'>QUOTE(knowledge @ Oct 3 2002, 03:52 AM)</div><div class='quotemain'><!--QuoteBegin-PLRacer@Oct 2 2002, 12:19 PM
Everyone want to know how much psi they can run with this or that! I will say this once! IT ALL DEPENDS ON WHAT SIZE TURBO YOU PLAN ON RUNNING! A TD05-12A@15psi pushes 320CFM's. A TD05/6-18G@15psi pushes 600CFM's. Almost twice as much! You could lets say run the 12A at 10psi safely, but once you swap it for a 16G (that pushes 505CFM's@15psi) you could only run it at 6psi safely. So from now on we need to see X turbo with Y motor! This would help get accurate info![/b][/quote]
good point...im gettin a drag 3 kit, so i will be using a t3/t4 hybrid turbo. now, what do you think?
&quot;sunshine plays a major part in the daytime.....peace to mankind ghostface carry your black 9...&quot;
Old 10-04-2002, 06:31 AM   #22
lol now you have to be even more specific... lol sorry what motor? Mods? Also I need to know what trim the T3/T4 you are gonna use is?
Reg-trim-585CFM's@15psi
S-trim-600CFM's@15psi
V-trim-700CFM's@15psi
In all honesty if it is a B series(excluding type-r) you will be fine with the reg and s-trim on a stock motor. 5-7psi without intercooler. With a D series I wouldnt think about running the regular trim over 5psi. If you have a D series make sure you use an intercooler or it might go boom after a month or so! The T3/T4's flow quite a but of CFM's! Thats what they are good for. Besides spooling up quick. Go to the Turbo section and compare the CFM's that I had Brian put in there of Mitsubishi turbo's. Greddy uses 18G's for their B and H series applications. D series greddy uses 15G's! Hope this helps.
Old 10-05-2002, 01:31 PM   #23
Rep Power: 16 Sed8ed is off the scale
Send a message via MSN to Sed8ed
If you are running a high lift cam then you will/should probably run a stronger, stiffer valve spring. Call delta cams in tacoma wa. (i'll post the info later when I find it) they will weld build and regrind your stock cam for about $100 or send you a new one for about $250 without core. If you sent them the spec's for the crower cam then they can make it as well. As for valves, I picked up a set of stainless exhaust valves, 1mm overbore, for $14cdn (about $8usd) each, for the D17 project so shop around.
Oh yeah, if you cooked any of the valves, get a machine shop to take a look at the damage, and give you an estimate on installing larger valves. You can install new valves yourself but it is a lengthy process. If you really want to know I will post it up later.
'Due to budget cuts, the light at the end of the tunnel has been turned off.'
'Out of my mind, back in five minutes'
Originally posted by simba
Canada didn't become a communist state, it became a socialist country run by liberal housewives who think cause and effect is black and white.
Own a gun? Well, it's probably going to cause someone to be shot sooner or later. Better restrict them.
Own a fast car? Well, you're probably going to kill someone due to driving too fast sooner or later. Better give the police unlimited power to &quot;convince&quot; you to return it to stock, so you won't kill anyone. Freedom is subjective.
Sed8ed is offline   Reply With Quote
Old 10-05-2002, 06:00 PM   #24
Rep Power: 15 dubster99 is off the scale
The endyn pistons are just wiesco pistons that have been sanded to take off the rough edges. Yes valvetrain is worth it, especially if you are going to get a turbo grind cam...Crower makes great turbo cams. With a built block you'll be able to easily take 12 psi.
Brett
<img src=\'http://nrg-racing.com/images/dv8/aj/dv8_logo.jpg\' border=\'0\' alt=\'user posted image\'>
Juiced 97 CGP TEG GS
What I have noticed is people who say nitrous is bad, nitrous sucks, blah blah blah. But they don't have technical information to back it up....&quot;its just cheap&quot;.....well hmm. If I spend less money than you, and am way faster, who's the smart one?
dubster99 is offline   Reply With Quote
Old 10-06-2002, 05:50 PM   #25
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Endyn does polish the pistons... but the Rollerwaves are Wiseco pistons built to Endyn's specs.
B18a and B18b info please importjdmcivic HYBRID -> EG-EK / DC 13 06-19-2008 02:39 PM
FS: Parting out B18B '94 or '95 Blanco Parts: For Sale/Trade/Wanted 64 12-14-2004 12:15 AM
B18B build up Blanco Engine Building 60 06-25-2004 09:39 PM
b18b valve cover jinstuh Engine Building 3 02-03-2004 07:06 AM
B18b N/a Build In A 92-95 Civic Ex Coupe thepester Engine Building 3 03-15-2003 02:57 AM
