hey guys,
i plan on putting a b16 head on. i eventually want to boost it later. i am slowly learning more and more about the complications within the build. but i want to know if you guys can help me clarify some things. b16 head requires p30 ecu? or will p72 work, chipped? how reliable is the ls water and oil pump. if i leave them, stock ls timing belt will work right? if i plan to boost at around 12 pounds, would just pistons, rings and rod bolts, and bloack guard be enough? how sturdy are ls rods? what do lma's do? finally, how easy and reliable is the golden eagle ls/vtec conversion kit to install? |
#2 | |||
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
Edit: A little slow here. Lost motion assemblies. They dampen the motion of the VTEC follower when VTEC is not engaged. You need them. I didn't use it, but if it had been available when I did mine I would have. __________________
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com Last edited by lsvtec; 09-14-2006 at 08:53 PM. Reason: Decoded LMA |
see im really trying to decide wether to just slap one of those ssautochrome turbo kits on and see how it happens...i had a fully built boosted 99 si and i cant get away from boost, but i miss vtec too. so i donno if i want to boost for fun or vtec it for reliability. i know someone who's had their ss manifolds boosting at 18 lb's and has had it on for over 6 months.
#4 | |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
after 96 the pumps are all the same, or it might be 98, i forget... but everything else is great ![]() __________________
| Rebuild B18C or build Ls/Vtec? | freddycivic | Engine Building | 14 | 06-22-2008 12:18 PM |
| LS/Vtec Supercharged Build | Acura_GS90 | Engine Building | 3 | 02-27-2006 11:28 PM |
| How to build 220 HP with LS/VTEC | mdixonjam | Engine Building | 23 | 06-14-2005 03:52 PM |
| Ls/vtec Build | Mech | HYBRID -> ED-EF / DA | 18 | 06-12-2003 12:17 PM |
| B18b N/a Build In A 92-95 Civic Ex Coupe | thepester | Engine Building | 3 | 03-15-2003 02:57 AM |
