b18c1 stock sleeves hold 13.5 compression pistons
Old 06-13-2008, 04:52 PM   #1
Rep Power: 0 jdmontheway is on a distinguished road
Default b18c1 stock sleeves hold 13.5 compression pistons
i have a b18c1 block w/an ls crank rods and a block guard.. the head is going to be p&p valve springs/retainers , all that good stuff . would 13.5 supertech pistons im running race gas lsd you know what do you guys think
jdmontheway is offline   Reply With Quote
Old 06-13-2008, 05:58 PM   #2
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Say again? Are you trying to ask something along the lines of the pistons being good for your set up? I'm confused. What are your goals first of all?
EDIT: I forgot to mention, get rid of the block guard. It is going to cut off your coolant flow a lot. I would consider getting sleeves if you really want the reinforcement and peace of mind instead.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 06-15-2008, 12:21 AM   #3
Default b18c1
would stock sleeves hold that compression im going all motor
Old 06-15-2008, 03:24 PM   #4
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Um, yes. You definitely won't be making 350+ whp so sleeves shouldn't be a concern. Rods may be a concern if you squeeze enough power out of it. From the sound of it, you don't really know what you're doing. Is someone building this for you?
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 06-15-2008, 10:46 PM   #5
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Your stock sleeve will hold that compression just fine. Like Luis said, get rid of the block guard. There's no need to resleeve at those power levels either. DO definitely have the engine tuned by someone who knows what they're doing. Detonation kills sleeves WAY before high power levels do. You can get 13.5 compression to run just fine on pump gas too if you have the right cams and know how to tune.
Old 06-17-2008, 10:43 PM   #6
Calesta's Avatar
Ride:  2003 S2000
Not necessarily. Remember, RIGHT CAMS.
Old 06-17-2008, 11:34 PM   #7
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 43 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Still, 13.5:1 compression is a waste of time when tuned on pump. He wont even get to take advantage of the power it can make on pump gas. He is going to have to use a mild lift/short duration camshaft, being its an ls crank. With that long rod stroke its gonna be hell spinning it higher than 8200rpm regardless of what build it is. Even with S2S1's, he would still have to retard the timing, I dont care if god tunes it himself.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 06-17-2008, 11:38 PM   #8
Calesta's Avatar
Ride:  2003 S2000
Huh? Where are you getting your info from? You want a LONGER duration LONGER overlap cam setup for high static compression. That rod/stroke setup doesn't have ANY problem spinning WELL past 8200rpm too.
Old 06-19-2008, 03:36 AM   #9
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Did you fail to notice the part where he is using an LS crankshaft? Do your homework and you will understand that long rod stroke + your long duration camshaft = guaranteed bearing failure at high rpms. 13.5:1 compression is worthless when tuned on 93, bottom line. Been there, done that. 12:1 - 12.5:1 will be suitable for 93 octane pump gas. I dont care who builds that engine, it will fail at high rpm's, bottom line.
Old 06-19-2008, 03:50 AM   #10
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 227 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
I thought all the 1.8s shared the same stroke.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 06-19-2008, 08:21 AM   #11
Calesta's Avatar
Ride:  2003 S2000
Uh... yeah, I did notice. I built several. I've tuned many. I know what I'm talking about. Do you really think that 1.58:1 is really that different from 1.54:1 on your rod stroke ratio? GSR cranks spin that high. Put in a 1.8mm longer stroke crankshaft into the same block and it's perfectly fine if you've built it properly.
Old 06-19-2008, 09:37 AM   #12
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
lol...its like he doesnt understand what you do for a living cal....believe me...its a lot more technically complicated than making a ls spin above 8200rpms.
Anime Informant
reikoshea is offline   Reply With Quote
Old 06-19-2008, 02:09 PM   #13
HS Troll...And Mod
reikoshea's Avatar
myspace
Originally Posted by Blanco View Post
Well Cal, all I can say is that I'm coming from people who both their own flow bench and dyno. Even the flow bench manuals recommend against more than 12:1 on pump gas and rather recommend using compression based on what octane you're running. I trust your opinion with many things, but not with this.
Remember, your 13.5:1 engine burned up because of a bad tune
. My 9.5:1 engine has ridiculously advanced timing.
Damn....he went there.
Anime Informant
Old 06-19-2008, 09:23 PM   #14
Calesta's Avatar
Ride:  2003 S2000
I make bullets that hit bullets- except one bullet is trying to dodge the other bullet at thousands of miles per hour.
Remember, your 13.5:1 engine burned up because of a bad tune. My 9.5:1 engine has ridiculously advanced timing.
So does mine. Don't worry, building an engine with a static compression that high to run on pump gas is pretty stupid most of the time. You just need high static compression to make a crazy overlap cam setup work well- you need the static compression to keep the dynamic compression up when you're bleeding out in the overlap phase. It's doable, but you have to be damn good.
My engine was 12.8:1, and yes it was a bad tune- by a California retard that I shouldn't have trusted to even touch the engine. I got screwed on the whole deal- paid for a half day of dyno time and got 45 minutes and 9 pulls, then didn't get a retune when I kept badgering him to be more conservative for Texas heat. Oh well, live and learn. Now I know better tuners, and I know for sure that my tuning is better than Jeff's. By a long shot.
No biggie. Mistakes happen. My first two builds ran a ton better, and even my own tune on the third build was better than the tune that blew it apart!
Integra Civic GSR B18C1 Pistons Wiseco High Compression RSS-Bot Auctions 0 03-22-2008 04:53 PM
Integra Civic GSR B18C1 Pistons Wiseco High Compression RSS-Bot Auctions 0 03-16-2008 09:33 PM
should i get some darton mid sleeves and arias low compression pistons turbowagon92 Engine Building 2 08-24-2006 08:32 AM
Which Sleeves, Which pistons? Johnnylawless Engine Building 32 05-17-2004 09:15 PM
High compression SLEEVES Elo'rin Engine Building 15 05-13-2004 12:29 AM
