B20 Compression
Old 02-13-2003, 07:27 PM   #1
Rep Power: 16 5genracer is off the scale
Thumbs up
I am sending my b20 block off to get sleeved soon, and I would like to know if anybody runs a 12.5:1 CR in their motors. If you do, what kind of upkeep/maintainence if required for this high of a CR? I already have a Hondata, so tuning is covered. What kind of power could I make out of this setup: sleeved b20, 12.5:1 CR, CTR cams, skunk2 valvetrain, eagle rods, light flywheel, 99 Si tranny, head that was port matched to the stock intake manifold and had the ridges before the valve seats removed and the entire thing mildly polished. Sorry for the long confusing sentence. Thanks!
02 Sebring Silver / Red S2000
5genracer is offline   Reply With Quote
Old 02-13-2003, 07:28 PM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
i believe that calesta runs 12.6:1 on his b20/vtec or should i say ran... it's currently being rebuilt.
pills_PMD is offline   Reply With Quote
Old 02-13-2003, 08:43 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Who knows about power... maybe 220whp? 230whp? It could be anything, depending on your tuning. You're probably safe at estimating at least 210whp though.
As for upkeep, just pay close attention to the engine... check fluid levels every time you get gas, go hit the dyno every now and then to make sure it's all in check, be vigilant with your oil changes and tranny fluid changes, etc- you'll be fine.
Old 02-13-2003, 10:03 PM   #4
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
^^^^ that, and don't race corvettes heheehehehe <_<
Old 02-13-2003, 10:15 PM   #5
B16
B16's Avatar
man, you've been mean lately
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 02-13-2003, 11:46 PM   #6
Calesta's Avatar
Ride:  2003 S2000
At least I COULD.
:P
Old 02-14-2003, 12:17 AM   #7
Retired OG
Ride:  Integra, Tahoe
Rep Power: 43 kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
Originally posted by 5genracer@Feb 13 2003, 07:32 PM
...CTR cams...
uh.... ctr cams in a b20 head?
Kyle I. Collins, PmD.
kyleirwin is offline   Reply With Quote
Old 02-14-2003, 03:17 AM   #8
Calesta's Avatar
Ride:  2003 S2000
Originally posted by kylemarhx+Feb 13 2003, 11:22 PM--><div class='quotetop'>QUOTE(kylemarhx @ Feb 13 2003, 11:22 PM)</div><div class='quotemain'> <!--QuoteBegin-5genracer@Feb 13 2003, 07:32 PM
...CTR cams...
uh.... ctr cams in a b20 head? [/b][/quote]
I'm assuming that he's getting a VTEC head put on at the same time.
Old 02-14-2003, 04:41 AM   #9
Retired OG
Originally posted by Calesta+Feb 14 2003, 03:22 AM--><div class='quotetop'>QUOTE(Calesta @ Feb 14 2003, 03:22 AM)</div><div class='quotemain'>
...CTR cams...
I'm assuming that he's getting a VTEC head put on at the same time. [/b][/quote]
i would hope so .
Old 02-14-2003, 08:36 AM   #10
yeah b20/VTEC! By the way, I live in the frozen north (ND), so do you think that I will have a hard time starting it in the winter?
Old 02-14-2003, 10:44 PM   #11
Rep Power: 15 10K2HVN is off the scale
Wow! Set-up sounds good..what sleeves are you getting..? Pistons (namebrand)? Bore?
Black 1995 ACURA INTEGRA GS-<span style=\'color:red\'>R</span>
-B20PR3
-Type-<span style=\'color:red\'>R</span> headers, oil pump, water pump, valves.
-JG Port&amp;Polish, ValveSprings, Ti Retainers
10K2HVN is offline   Reply With Quote
Old 02-15-2003, 09:49 PM   #12
Je forged pistons, not sure of the sleeve brand. Whatever importbuilders.com uses.
Old 02-16-2003, 03:15 AM   #13
RETIRED
they use ge
compression, octane, and boost rjbaker Engine Building 6 01-24-2004 04:03 PM
Static vs. Effective Compression pissedoffsol Turbo Information 0 01-12-2004 01:43 AM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 01:41 AM
High Compression & Nitrous michaelgomez Forced Induction 1 06-06-2003 02:57 PM
Compression Question 22crazy Engine Building 13 12-29-2002 04:23 AM
