Am I missing anything?? Oil pump? Timing Belt? Nething necessary to run this setup.. I know that the cams, sleeves and traction bars arent necessary, those will be done later.. but I wanted to basically have a somewhat forged setup done and be able to run the setup with no problems.
B20 block B18C5 head 18" -4AN steel braided hose 2 x -4AN fittings 1/8"NPT to 1/8" BSP Tee fitting 1/8"NPT to -4AN adapter fitting -4AN to 3/8NPT fitting 1/8"NPT plug JE Pistons 9:1 Eagle Rods & Arp Rod Bolts Arp Head Bolts RC Injectors 550 cc (peak and hold or saturated?) Oil Catch Can pcv mod for b20 block (this is a must) Golden Eagle Godzilla Sleeves Skunk2 Turbo Cams Skunk2 Cam Gears Machine Work on Head/Block Hondata s200 w/ boost option OBD I ECU (JDM ITR) B18C5 Tranny w 4.7 Final Gear VTEC Shift Linkage AEM Fuel Rail B Series Distributor CM Stg 4 Clutch Axles & Mount Brackets ACT Street Lite 11.9lb flywheel Traction Bars |
RETIRED
Here's what i'd replace:
B20 block - sleeved by GE b18b. once sleeved to 84mm, the b20 is just a more expensive choice of the exact same thing. RC Injectors 550 cc (peak and hold or saturated?) - its in there...OBD I ECU (JDM ITR) - see what pills said B18C5 Tranny w 4.7 Final Gear - GSR with quaiffe AEM Fuel Rail - Golden Eagle CM Stg 4 Clutch - ACT Axles & Mount Brackets - HAspot mounts rock ACT Street Lite 11.9lb flywheel - don't. stay stock. Traction Bars - jimfab.com |
on what pills and pissed said.I would also add fresh new vtec oil and water pumps, a new oem timing belt, and replace every gasket (which I am sure you will be doing anyways) Might want to consider some type of stronger aftermarket axles if planning to use slicks or have high power. And don't go with a B20, like pissed said if you are sleeving it then it's the same shit. Milan __________________
| Need Advice on turbo setup | eastkoastkustumz | Forced Induction | 8 | 07-01-2004 07:38 PM |
| How does this setup sound??? | Dustin_m | General Tech and Maintenance | 11 | 01-25-2004 08:21 PM |
| ls/vtec werd | KWJaY | Engine Building | 11 | 09-10-2003 05:39 PM |
| Want A High Revving Monster? | maverick97 | Engine Building | 10 | 06-26-2003 04:25 PM |
