I have a b20b with b16 vtec head and 12 cr. I will be dynotuning with hondata so do I still need to upgrade injectors or can hondata compensate for it? I was planning on using stock injectors? Is it really necessary? I have ctr valvetrain and revving to only 8k. I am using walbro 255lph and aem fpr and fuel rail
Khai __________________
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a> |
How hard are they to take out and put in. I am basically worrying about emissions and dmv and having to swap things out and in. For now all i have to worry about is a test pipe and ecu.
KHai __________________
to swap out injectors? easy man..
and i'd go with 440's __________________
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#6 |
Admin with a big stick
Ride: 2003 S2000
You can do it if you crank up the fuel pressure some- mine ran on 240s for a good while.
#7 |
How did it run Calesta? Good enough? I have an aem fpr.
#8 |
also to consider the prelude injectors which I think run 270 if not mistaken
#9 | |
Ride: 2003 S2000
