B20B Headgasket.
Old 11-02-2009, 10:00 PM   #1
Greenhorn
Ride:  '91 Integra GS with B20B
Rep Power: 0 Nightwars is on a distinguished road
Default B20B Headgasket.
Hi,
In an attempt to raise my B20B compression I thought about using a thinner headgasket.
The one I actually have is a 3 layer oem gasket, since I have the P3F Pistons, I have a very low compression motor.
What if I change the headgasket by a 1 layer headgasket?
Would that work? The Compression Calculator located here.
Honda B-Series Compression Calculator by ZealAutowerks
Tells me that I would raise my comp from 8.86 to 9.16, is it worth it?
What kind of gain should I expect?
The car is a 1991 Integra 2 doors with a 1997 CR-V engine in it (Its autotragic also) I plan on swapping the tranny next spring.
I'm also open to any basics mods that could increase the responsiveness of my engine and its power.
I have the whole winter to gather funds so if you have any suggestions I'm all ears!
Thank you.
Nightwars is offline   Reply With Quote
Old 11-03-2009, 06:21 PM   #2
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
It's not worth the cost/effort for the .3 gain in compression. For example, the US b18c1 (gsr) is rated at 170 hp. The JDM b18c (gsr), is 180hp. The only difference is that the jdm motor has .5 higher compression. Based on that, you might be lucky to see 5 hp at the crank by changing to that thinner gasket.
Save your money for an ITR transmission. The short gearing coupled with an LSD will really wake up the car.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 11-03-2009, 07:56 PM   #3
Greenhorn
Any idea how much they run for these days?
Old 11-03-2009, 08:59 PM   #4
99sidude's Avatar
$600-1000. They arn't cheap. You can also get a b16 or gsr transmission and install an aftermarket lsd. I'm guessing that might actually end up costing a bit more.
93' dx hatch
s300 440cc RC's
headgasket ? b17a1civic Engine Building 1 10-01-2007 09:44 PM
headgasket CiViChAtChBaCkMn General Tech and Maintenance 2 04-01-2005 11:05 AM
HKS headgasket Franknstein Forced Induction 9 07-29-2004 10:39 AM
new headgasket? Del Slw Engine Building 7 04-19-2004 03:05 AM
Better headgasket? get_nick Engine Building 1 06-25-2003 07:21 PM
