b20vtec compression
Old 11-13-2008, 03:42 PM   #1
Default b20vtec compression
Someone please help me figure out my compression...
I'm building an 84.5mm B20VTEC.
B20B Block
LS/B20 Rods
LS/B20 Crank
84.5mm RS ITR pistons
3 layer OEM headgasket
Supertech flat "race" valves
GSR head which has ported/polished will flow right around 280-285cfm
Can anyone help? I've heard numbers all the way from 11:1 to 13:1, I just really wanna know.
90 Integra Sedan
B20V 225 / 153
Old 11-22-2008, 11:24 PM   #2
xips(86CRXSI)'s Avatar
Ride:  91 si hb gsr swap
Rep Power: 10 xips(86CRXSI) is off the scale
myspace
Go here, ZealAutowerks - Honda Compression Calculator
and you need to know if your pistons are usdm or jdm Itegra Type R.
xips(86CRXSI) is offline   Reply With Quote
Old 11-23-2008, 12:36 AM   #3
something tells me thats not going to be very accurate.
90 Integra Sedan
B20V 225 / 153
Old 11-23-2008, 02:41 AM   #4
myspace
did you try it?
Old 11-23-2008, 06:01 AM   #5
Ya, 13.5 and everyone I talk to says thats not even close to being accurate. Since I guess the calculator still assumes the pistons are 81mm going into an 84.5 bore.
I didnt say its wrong as a fact, I expressed an opinion about it possibly being wrong
90 Integra Sedan
B20V 225 / 153
High Compression Build vs. Low Compression Build? Trying to clear something up.. oneofakinduserid Engine Building 14 10-08-2009 04:02 PM
b20vtec gomes Engine Building 22 10-03-2009 11:47 AM
b20vtec help SplitzO Engine Building 20 12-14-2006 11:25 PM
B20VTEC compression ?'s EGLSHB General Tech and Maintenance 3 11-11-2003 10:30 PM
b20vtec KWJaY HYBRID -> ED-EF / DA 5 08-20-2003 01:40 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
